I have created an MQTT device using an ESP8266 and can see in the serial console that the following payload is sent to Mosquitto:
"uniq_id": "d9be9d",
"name": "My ESP Dimmer",
"dev_cla": "light",
"stat_t": "homeassistant/light/d9be9d/state",
"cmd_t": "homeassistant/light/d9be9d/state/set",
"brightness_state_topic": "homeassistant/light/d9be9d/Brightness",
"brightness_command_topic": "homeassistant/light/d9be9d/Brightness/Set",
"brightness_scale": "12345",
"optimistic": false,
"retain": false
However, in the Home Assistant log I see the following:
2023-03-06 16:11:55.122 ERROR (MainThread) [homeassistant.util.logging] Exception in async_discover when dispatching 'mqtt_discovery_new_light_mqtt': ({'unique_id': 'd9be9d', 'name': 'My ESP Dimmer', 'device_class': 'light', 'state_topic': 'homeassistant/light/d9be9d/state', 'command_topic': 'homeassistant/light/d9be9d/state/set', 'brightness_state_topic': None, 'platform': 'mqtt'},)
File "/usr/src/homeassistant/homeassistant/components/mqtt/mixins.py", line 316, in async_discover
config: DiscoveryInfoType = discovery_schema(discovery_payload)
File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 232, in __call__
return self._exec((Schema(val) for val in self.validators), v)
File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 355, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 351, in _exec
v = func(v)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 818, in validate_callable
return schema(data)
File "/usr/src/homeassistant/homeassistant/components/mqtt/light/__init__.py", line 41, in validate_mqtt_light_discovery
config: ConfigType = schemas[config_value[CONF_SCHEMA]](config_value)
v = func(v)
return schema(data)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 595, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 433, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: string value is None for dictionary value @ data['brightness_state_topic']
So somewhere along the way, the value of the “brightness_state_topic” attribute is lost.
I see nothing useful in the Mosquitto logs.
Any idea what may be going on or how to further debug it?
