MQTT door sensor sketch for ESP
I’ve setup a simple magnetic door sensor via MQTT and using a NodeMCU board but for some reason my sketch will not update the MQTT Broker as the magnetic switch changes. The NodeMCU lights up with each change so I know the actual physical device is working.
Anyone keen to have a quick look through my sketch and tell me where it is amiss? It compiles and loads alright but I’m probably staring at the issue and keep overlooking it.
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#define MQTT_VERSION MQTT_VERSION_3_1_1
// Wifi: SSID and password
const PROGMEM char* WIFI_SSID = "******";
const PROGMEM char* WIFI_PASSWORD = "*******";
// MQTT: ID, server IP, port, username and password
const PROGMEM char* MQTT_CLIENT_ID = "lounge_door";
const PROGMEM char* MQTT_SERVER_IP = "192.168.1.***";
const PROGMEM uint16_t MQTT_SERVER_PORT = 1883;
const PROGMEM char* MQTT_USER = "*******";
const PROGMEM char* MQTT_PASSWORD = "******";
// MQTT: topic
const PROGMEM char* MQTT_DOOR_STATUS_TOPIC = "lounge/door/status";
// default payload
const PROGMEM char* OPENING_ON = "OPEN";
const PROGMEM char* OPENING_OFF = "CLOSED";
// DOOR : D1/GPIO5
const PROGMEM uint8_t DOOR_PIN = 5;
uint8_t m_door_state = LOW; // door closed
uint8_t m_door_value = 0;
// macros for debugging
#ifdef DEBUG
  #define             DEBUG_PRINT(x)    Serial.print(x)
  #define             DEBUG_PRINTLN(x)  Serial.println(x)
#else
#endif
WiFiClient wifiClient;
PubSubClient client(wifiClient);
// function called to publish the state of the door sensor
void publishDoorSensorState() {
  if (m_door_state) {
    client.publish(MQTT_DOOR_STATUS_TOPIC, OPENING_OFF, true);
  } else {
    client.publish(MQTT_DOOR_STATUS_TOPIC, OPENING_ON, true);
// function called when a MQTT message arrived
void callback(char* p_topic, byte* p_payload, unsigned int p_length) {
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("INFO: Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect(MQTT_CLIENT_ID, MQTT_USER, MQTT_PASSWORD)) {
      Serial.println("INFO: connected");
    } else {
      Serial.print("ERROR: failed, rc=");
      Serial.print(client.state());
      Serial.println("DEBUG: try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
void setup() {
  // init the serial
  Serial.begin(115200);
  // init the WiFi connection
  Serial.println();
  Serial.println();
  Serial.print("INFO: Connecting to ");
  Serial.println(WIFI_SSID);
  WiFi.mode(WIFI_STA);
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("INFO: WiFi connected");
  Serial.println("INFO: IP address: ");
  Serial.println(WiFi.localIP());
  // init the MQTT connection
  client.setServer(MQTT_SERVER_IP, MQTT_SERVER_PORT);
  client.setCallback(callback);
void loop() {
  if (!client.connected()) {
    reconnect();
  client.loop();
  // read the DOOR sensor
  m_door_value = digitalRead(DOOR_PIN);
  if (m_door_value == HIGH) {
    if (m_door_state == LOW) {
      // door is opened
      Serial.println("INFO: door opened");
      publishDoorSensorState();
      m_door_state = HIGH;
  } else {
    if (m_door_state == HIGH) {
      Serial.println("INFO: Door closed");
      m_door_state = LOW;
You can try this code:
I think it would be useful if you pasted the serial port output.
I think your problem may be here, does m_door_state equate to true or false, or HIGH or LOW?
Thanks, you were right, it should be HIGH/LOW not true/false.
Got to read now at least one change but it won’t continue to read changes so still some more errors to flush out
Hi, your project is really interesting. Do you have the definitive scketch you can post? What do you write in the yaml file to view the sensor in HA? Thank’s!!!
Hi, I copied the Arduino code. Can you tell me what to write in the yaml file? thank you
It would probably help if you replied to the person that started the thread @jonathanp, he will probably be able to help you :slight_smile:
Sorry, I ended up changing to 433mhz door sensors in the end so I do not have the YAML entry anymore.
