You can try this way
service: mqtt.publish
topic: C6D6/zone0/text
payload_template: 'pit {{states(''sensor.meat_probe_1'')}} °F'
thanks !
Grey
This build does not show the IP on boot?
Grey
Oh yes, looks like I forget to return this function. The next release will show IP on boot.
I received new display segments. What do you think about these white real pixel segments? They work as default red/blue/green segments, I just replace my red segments with these whites. White segments are very bright in comparison with red ones.
Depends on where you use them. Indoors white would be fine or outside after dark. I have blue and red so far.
They look interesting. I plan to build 12 modules (red) that are supported and replace the first module where the weather icon will be displayed with a blue one.
love the idea of changing module colors !
Hi
I plan to build a 2 x 6 module (2 rows and 6 segments).
Is it possible to let characters to span over two rows? To make text bigger?
I think the component doesn’t allow it. A maximum of 12 LED modules in a row with the possibility of dividing into three zones.
It wouldn’t look good. I have built 12 modules in a row and it looks great as an information display.
At the moment, the project does not support double-height elements. At the same time, the library itself used in the project supports this.
I do not plan to add this functionality yet, because it will take a lot of time and I don’t have it. But I will be glad if someone adds this functionality to my open-source project.
I’m thinking to add several more zones in the some nearest future, may be it will help you in some cases.
How hard would it be to invert a zone?
As in when they are one above the other the connectors are both on the left side
Grey
Here is an information display of 12 modules.
First module replaced (blue color).
I am very satisfied with this component.
Look great
where did you get the housing for the modules?
This is self-made. Acrylic glass dark, black plastic plate and frame is AL profile U.
The rear parts and sides are a white 3mm plastic plate.
Does this support P10 RGB panels? If not does anyone know of an ESP project that does?
These LED modules have 1 color.
If you want rgb, try this project: https://github.com/lubeda/EsphoMaTrix
Please note that the LED panel is larger. I have one built and it works fine too
Thank you!
New release with Home Assistant MQTT discovery [v2.3]:
New features:
Power
- on/off powerBrightness
values from 1 to 15Zone work mode
for each zonesCharspacing
for each zonesScroll align
for each zonesScroll pause
for each zonesScroll speed
for each zonesScroll effect IN
for each zonesScroll effect Out
for each zones! When MQTT settings specified, device will be automatically send discovery message to HA.
By default light device will be added to Home Assistant with power and brightness control. All other controls listed above you find in device settings in integrations. You can use all of them in HA automations.
Deprecations:
Download on GitHub: Release Home Assistant MQTT discovery · widapro/wledPixel · GitHub
Hello, How did you get the rest of the configuration show up in HA? I see only controls in MQTT devices section. Thanks in advance…
