Hello everyone,
I connect to Home Assistant via MQTT, including Homey. Everything has worked great so far. I have now changed the broker and then deleted the existing broker in the MQTT integration and created a new connection. The devices there are the same as before. However, the name is given twice after the MQTT Auto Discover. As a result, all dashboards no longer work because the entity now has a different name.
Example:
Before the change:
Entity ID: climate.heating_workroom
After the change:
Name: Heating workroom Heating workroom
Entity ID: climate.heating_workroom_heating_workroom
What should i do?
