MQTT dynamic topic publish2
Hi!
I have multiple blinds connected to custom (esp32) device to tilt and open/close.
I’m using MQTT to communicate with the esp32 and everything work fine to get/set data (with node-red)!
Now I want to set limits for the motors. I’ve created helpers and add it to lovelace in sort of button.
I’ve connect the “buttons” to call service and select mqtt.publish .
At this time, i’m able to run a motor completely!
via custom topic : blinds/BLIND-001/state
but I want to run the orhers motors via other topic
(blinds/BLIND-xxx/state)
thats why i’ve made the first input (slider) … to switch the motor that I want to control.
I’ve try with this yaml (i put only 1 button here)
type: button
icon: 'mdi:blinds'
tap_action:
action: call-service
service: mqtt.publish
service_data:
    payload: downTilt
    topic: 'blinds/BLIND-00{{states("input_number.blindselector"}}/state'
entity: input_boolean.tilt_down
the payload is send to topic:
blinds/BLIND-00{{states(“input_number.blindselector”}}/state
… in other words… the {{ … }} is treated litteraly and not compute the state of my input_number.blindselector
​my questions is:
How can I concatenate string with variable in the current yaml?
thanks in advance (and sorry for my english)
The call-service action does not accept templates. That means the template you created in topic is unsupported.
Create a script to tilt a blind and then set call-service to call the script.
tap_action:
  service: script.tilt_blind
The script can contain most of your existing code:
tilt_blind:
  alias: Tilt Blind
  sequence:
  - service: mqtt.publish
      payload: downTilt
whoa!!! :dizzy_face: it’s working!!! :hugs:
Big thanks!
Discover Script made my day!
Thank you very much!
