Hi all,
I’m trying to get an older configuration running but only one of my manually-configured MQTT devices show up as an entity. I think I’m just missing some detail in the config files. I’m hoping some kind soul will look at my config files and point out the issue.
One interesting thing is that the only MQTT device that shows up is the MBR Bath Fan. I have no idea why that one device shows up, as far as I can see this one is defined the same as the others.
Thanks in advance,
Bill
my configuration.yaml - note most of the commented-out stuff used to work but now throws errors.
homeassistant:
name: The Shaw Estate
latitude: !secret secret_lat
longitude: !secret secret_long
elevation: 239
unit_system: imperial
time_zone: America/New_York
# customize: !include customize.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
weather:
- platform: darksky
api_key: !secret darksky_key
frontend:
# javascript_version: latest
themes: !include themes.yaml
# extra_html_url: /local/custom_ui/state-card-floorplan.html
# Show the introduction message on startup.
#introduction: Welcome to the Shaw Estate.
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Discover some devices automatically
discovery:
recorder:
# Delete events and states older than 1 week
# purge_keep_days: 7
# purge_interval: 3
# db_url: !secret db_url
commit_interval: 15
# Enables support for tracking state changes over time
history:
# enable ios integration
#ios:
# View all events in a logbook
logbook:
# add logging for mysensor
logger:
default: info
logs:
homeassistant.components.binary_sensors: debug
#mysensors: debug
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
mqtt: !include mqtt.yaml
#panel_custom:
# - name: floorplan
# sidebar_title: Floorplan
# sidebar_icon: mdi:home
# if you change the name of your floorplan.svg file, change it here too.
# url_path: /local/custom_ui
# js_url: /local/custom_ui/floorplan.html
# config: !include floorplan.yaml
#panel_iframe:
# configurator:
# title: Configurator
# icon: mdi:wrench
# url: http://192.168.1.64:3218
#binary_sensor: !include binary_sensors.yaml
#sensor: !include sensors.yaml
#switch: !include switches.yaml
# people tracker
#device_tracker:
# - platform: ping
# interval_seconds: 30
# consider_home: 600
# hosts:
# dads_iphone: 192.168.1.110
# yomammas_iphone: 192.168.1.122
# wills_iphone: 192.168.1.108
# cursed_images: 192.168.1.123
# darios_iphone: 192.168.1.101
# - platform: netgear
# host: 192.168.1.1
# username: !secret router_user
# password: !secret router_pass
# interval_seconds: 15
# Denon Receiver configuration
#media_player:
# - title: "Denon AVR"
# platform: denonavr
# host: 192.168.1.14
# name: Denon
# show_all_sources: true
# timeout: 2
# zones:
# - zone: Zone2
# name: MBR
# - zone: Zone3
# name: Garage
speedtestdotnet:
monitored_conditions:
- ping
- upload
- download
scan_interval:
minutes: 360
# - platform: ddwrt
# host: 192.168.1.1
# consider_home: 180
# new_device_defaults:
# track_new_devices: true
# CJB_1 Switches (relay outputs)
#switch:
# Text to speech
#tts:
# - platform: google
group: !include groups.yaml
script: !include scripts.yaml
eof
my mqtt.yaml -
## Switches for the Shaw Estate
# value_template: "{{ value_json.temperature }}"
# value_template: >
# "switch": {{ value_json.switch }}
# discovery: true
# discovery_prefix: hass
switch:
# - unique_id: mqtt.switch.sonoff_1
- object_id: mqtt.switch.sonoff_1
icon: mdi:light
command_topic: 'sonoff_1/switch'
payload_on: '{"switch":"ON"}'
payload_off: '{"switch":"OFF"}'
state_topic: 'sonoff_1/status'
state_on: '{"switch":"ON"}'
state_off: '{"switch":"OFF"}'
qos: 2
retain: true
switch:
- unique_id: mqtt.switch.sonoff_2
object_id: mqtt.switch.sonoff_2
name: "Living Room Lamp"
icon: mdi:light
command_topic: 'sonoff_2/switch'
state_topic: 'sonoff_2/status'
qos: 2
retain: true
switch:
- unique_id: mqtt.switch.kitchen_leds
object_id: mqtt.switch.kitchen_leds
icon: mdi:light
command_topic: 'kitchen/leds'
payload_on: '{"set_color":"white"}'
payload_off: '{"set_bright":"off"}'
# - payload_cycle: '{"set_color":"cycle"}'
state_topic: 'kitchen/status'
state_on: '{"color":"white","bright":"full"}'
state_off: '{"color":"white","bright":"off"}'
qos: 2
retain: true
switch:
- unique_id: front_lock
object_id: front_lock
icon: mdi:lock
command_topic: 'deadbolt_1/bolt'
payload_on: '{"bolt":"lock"}'
payload_off: '{"bolt":"unlock"}'
state_topic: 'deadbolt_1/status'
state_on: '{"bolt":"locked"}'
state_off: '{"bolt":"unlocked"}'
qos: 2
retain: true
switch:
- unique_id: sonoff_3
object_id: sonoff_3
icon: mdi:light
command_topic: 'sonoff_3/switch'
state_topic: 'sonoff_3/status'
qos: 2
retain: true
switch:
- unique_id: lower_bath_fan
object_id: lower_bath_fan
icon: mdi:fan
command_topic: 'lower_bath_fan/fan'
state_topic: 'lower_bath_fan/state'
# value_template: "{{value_json.switch}}"
qos: 2
retain: true
switch:
- unique_id: mbr_bath_fan
object_id: mbr_bath_fan
icon: mdi:fan
command_topic: 'mbr_bath_fan/fan'
state_topic: 'mbr_bath_fan/state'
qos: 2
retain: true
binary_sensor:
- name: "Clothes Washer"
state_topic: "Washer_room/washer"
value_template: "{{value_json.state}}"
binary_sensor:
- name: "Clothes Dryer"
state_topic: "Washer_room/dryer"
binary_sensor:
- name: "Water Room Wet Sensor"
state_topic: "Water_room/water_sensor"
binary_sensor:
- name: "Washer room wet sensor"
state_topic: "Washer_room/water_sensor"
binary_sensor:
- name: "Lower Bath Fan"
state_topic: "lower_bath_fan/state"
binary_sensor:
- name: "Master Bath Fan"
state_topic: "mbr_bath_fan/state"
# CJB IR motion detector inputs
binary_sensor:
- name: "Cellar"
state_topic: "cjb_1/ir_1"
device_class: motion
binary_sensor:
- name: "Lower Hall"
state_topic: "cjb_1/ir_2"
binary_sensor:
- name: "Cellar Stairs"
state_topic: "cjb_1/ir_3"
binary_sensor:
- name: "Computer Room"
state_topic: "cjb_1/ir_4"
value_template: "{{ value_json.state }}"
binary_sensor:
- name: "Living Room"
state_topic: "cjb_1/ir_5"
binary_sensor:
- name: "Garage"
state_topic: "cjb_1/ir_6"
binary_sensor:
- name: "MBR Stairs"
state_topic: "cjb_1/ir_9"
binary_sensor:
- name: "Solarium"
state_topic: "cjb_1/ir_10"
binary_sensor:
- name: "MBR Bath"
state_topic: "cjb_1/ir_11"
binary_sensor:
- name: "MBR"
state_topic: "cjb_1/ir_12"
binary_sensor:
- name: "Kitchen"
state_topic: "cjb_1/ir_13"
binary_sensor:
- name: "Guest Room"
state_topic: "cjb_1/ir_14"
# CJB switch inputs
binary_sensor:
- name: "Rear door"
state_topic: "cjb_1/switch_1"
device_class: door
binary_sensor:
- name: "Maddy's Window"
state_topic: "cjb_1/switch_2"
device_class: window
binary_sensor:
- name: "Cellar Door"
state_topic: "cjb_1/switch_3"
device_class: door
binary_sensor:
- name: "Alcove Door"
state_topic: "cjb_1/switch_4"
device_class: door
binary_sensor:
- name: "Alcove Window"
state_topic: "cjb_1/switch_5"
binary_sensor:
- name: "MBR Solarium Door"
state_topic: "cjb_1/switch_6"
device_class: door
binary_sensor:
- name: "MBR Stairwell Window"
state_topic: "cjb_1/switch_7"
binary_sensor:
- ame: "Front Door"
state_topic: "cjb_1/switch_8"
device_class: door
binary_sensor:
- name: "Bath Window"
state_topic: "cjb_1/switch_9"
binary_sensor:
- name: "Slider Door"
state_topic: "cjb_1/switch_10"
device_class: door
binary_sensor:
- name: "Will's Window"
state_topic: "cjb_1/switch_11"
binary_sensor:
- name: "Computer Room Window"
state_topic: "cjb_1/switch_12"
binary_sensor:
- name: "Upper Deck Door"
state_topic: "cjb_1/switch_13"
device_class: door
binary_sensor:
- name: "Car Door"
state_topic: "cjb_1/switch_14"
device_class: door
binary_sensor:
- name: "Garage Window"
state_topic: "cjb_1/switch_15"
binary_sensor:
- name: "Garage Door"
state_topic: "cjb_1/switch_16"
device_class: door
# Sensors
# class = window: On means open, Off means closed
# door: On means open, Off means closed
# motion: On means motion detected, Off means no motion (clear)
# moisture: On means moisture detected (wet), Off means no moisture (dry)
# battery: On means low, Off means normal
# Weather prediction
# - platform: yr
# name: "Weather Forcast"
- name: "Hot Water Temp"
state_topic: "Water_room/temp1"
device_class: temperature
unit_of_measurement: "°F"
- name: "Cold Water Temp"
state_topic: "Water_room/temp2"
- name: "Water Room Humidity"
state_topic: "Water_room/humidity"
value_template: "{{ value_json.humidity }}"
device_class: humidity
unit_of_measurement: "%"
- name: "Washer Room Humidity"
state_topic: "Washer_room/humidity"
- name: "Dryer Exhaust Temp"
state_topic: "Washer_room/temp1"
- name: "Dryer Temp"
state_topic: "Washer_room/temp2"
- name: "Washer Room Pressure"
state_topic: "Washer_room/pressure"
value_template: "{{ value_json.pressure }}"
device_class: pressure
unit_of_measurement: "mBar"
- name: "Water Room Pressure"
state_topic: "Water_room/pressure"
# bathroom fan sensors
- name: "Lower Bath Temp"
state_topic: "lower_bath_fan/temperature"
- name: "Lower Bath Humidity"
state_topic: "lower_bath_fan/humidity"
value_template: "{{ value_json.switch }}"
- name: "Master Bath Temp"
state_topic: "mbr_bath_fan/temperature"
- name: "Master Bath Humidity"
state_topic: "mbr_bath_fan/humidity"
value_template: '{{ value_json.switch }}'
# cjb_1 temp sensors...
- name: "Solarium Temp"
state_topic: "cjb_1/temp_1"
value_template: '{{ value_json.temperature }}'
- name: "Solarium Supply Temp"
state_topic: "cjb_1/temp_2"
- name: "MBR High Temp"
state_topic: "cjb_1/temp_3"
- name: "MBR Low Temp"
state_topic: "cjb_1/temp_4"
- name: "Return Air Temp"
state_topic: "cjb_1/temp_5"
- name: "MBR Collector Temp"
state_topic: "cjb_1/temp_6"
- name: "Garage Temp"
state_topic: "cjb_1/temp_7"
- name: "Pool Heater In Temp"
state_topic: "cjb_1/temp_8"
- name: "Pool Heater Out Temp"
state_topic: "cjb_1/temp_9"
- name: "Wire Closet Temp"
state_topic: "cjb_1/temp_10"
