Hi Guys,
I’ve installed mqtt, and decided after a few days to uninstall it.
even thought the it’s uninstalled, i’m getting errors in the log file for some reason.
tried reboot without success, can some help ?
error below:
2019-10-21 11:25:58 ERROR (MainThread) [homeassistant.components.mqtt] Failed to connect due to exception: [Errno -3] Try again
2019-10-21 11:25:58 WARNING (MainThread) [homeassistant.config_entries] Config entry for mqtt not ready yet. Retrying in 10 seconds.
2019-10-21 11:26:14 ERROR (MainThread) [homeassistant.components.mqtt] Failed to connect due to exception: [Errno -3] Try again
2019-10-21 11:26:14 WARNING (MainThread) [homeassistant.config_entries] Config entry for mqtt not ready yet. Retrying in 20 seconds.
2019-10-21 11:26:40 ERROR (MainThread) [homeassistant.components.mqtt] Failed to connect due to exception: [Errno -3] Try again
2019-10-21 11:26:40 WARNING (MainThread) [homeassistant.config_entries] Config entry for mqtt not ready yet. Retrying in 40 seconds.
2019-10-21 11:27:26 ERROR (MainThread) [homeassistant.components.mqtt] Failed to connect due to exception: [Errno -3] Try again
2019-10-21 11:27:26 WARNING (MainThread) [homeassistant.config_entries] Config entry for mqtt not ready yet. Retrying in 80 seconds.
