in a new installation of HA (2021.1 and python 3.8) when starting Ha in the Logs tab I get this error …
Failed to connect to MQTT server due to exception: [Errno 111] Connection refused
At startup I have this automation but it doesn’t seems to work …
- alias: MQTT_STARTUP
- event: start
platform: homeassistant
condition: []
- data:
payload: announce
topic: shellies/command
service: mqtt.publish
at the startup my shelly bulbs in the interface are not clickable.
Executing it again by hand just after starting HA everything starts working again, even after several HA restarts everything is OK.
It is only when the rasp is restarted that I get this error. Did any of you find yourself in this situation ???
