The hour, minutes, seconds, background and hourmark colors and brightness can be controlled with Home Assistant (MQTT).
There is an ambient light sensor in the clock (to dim the display when the ambient light gets darker) the sensor lux values can be send to Home Assistant.
Hey @degraafm76, can I use a ESP8266 ESP-12E CH340G for NodeMcu V3, these I already have and I would like to use, if I can use these, any idea which diode I would need to remove, and if any configuration change is required?
Technically it would work, but the V3 version won’t fit in the case. One advantage of the V3 is that you wont have to remove the diode. PIN VU (VUSB) is directly connected to USB and can be used to power the leds.
