Mqtt_eventstream: sensors disappearing after a while
I just set up two HA instances that I tried to integrate via the MQTT Event Stream:
  • The master holds the majority of components
  • There is a slave in the basement that should integrate several ZWave components
When I start up both systems, everything’s find. However, after a while the ZWave components that were coming in through MQTT are just disappearing. None of the HA instances were restarted in the meantime.
Is there anything like a garbage collection that will get rid of sensors that haven’t been updated in a while? Because my ZWave sensors are all running on battery, so they will only change when they detect some change to the sensor state.
Did you ever find a fix for this? I’ve been ripping my hair out trying to resolve this same issue
Hi!
I have the same problem. Did any of you find any solution?
Best
Hi guys!
i have same issue here. Any ideas, workaround to this?
regards
