I’ve successfuly configured mqtt eventstream between my two Hasspbian isntances - components from slave instance load on master, master instance also shows proper state changes when I’m doing them on the slave instance. However, I am not able to change a state of device which is originally set on slave instance from master one. There is a notification from HA - “failed to run service”. On the Chrome dev tools - “service not found”. Does anyone have an idea how to change states/invoke actions from the “remote” instance (master in this case as the bluettoth device is a sensor on slave) via mqtt?
