The MQTT export component is a custom component which is sending all states and some details in one MQTT message.
Put the file mqtt_export.py file in the folder custom_components of your local Home Assistant configuration folder .homeassistant.
Your configuration.yaml file needs an entry for the component including the publishing topic (publish_topic).
mqtt_export:
publish_topic: "home/states"
Sample output:
"details":{
"latitude":46.9432,
"temperature_unit":"\u00b0C",
"version":"0.17.0.dev0",
"location_name":"Test room",
"time_zone":"Europe/Zurich",
"longitude":7.6034,
"components":[
"recorder",
"http",
"automation"
"states":[
"attributes":{
"friendly_name":"Bathroom window",
"sensor_class":"connectivity"
"last_updated":"14:10:57 06-04-2016",
"state":"off",
"entity_id":"binary_sensor.bathroom_window",
"last_changed":"14:10:57 06-04-2016"
"attributes":{
"next_setting":"18:06:45 06-04-2016",
"next_rising":"04:56:02 07-04-2016",
"friendly_name":"Sun",
"elevation":37.39
"last_updated":"14:11:30 06-04-2016",
"state":"above_horizon",
"entity_id":"sun.sun",
"last_changed":"14:11:09 06-04-2016"
Source: https://github.com/fabaff/home-assistant-mqtt-export
