I am about to pull my hair out. I am trying to simply setup a sonoff basic and I think I have done everything correctly but obviously not.
My sonoff switch has this in the console.
03:29:38 MQT: Attempting connection...
03:29:38 MQT: Connect failed to 192.168.1.50:1883, rc 5. Retry in 10 sec
03:29:49 MQT: Attempting connection...
03:29:49 MQT: Connect failed to 192.168.1.50:1883, rc 5. Retry in 10 sec
03:30:00 MQT: Attempting connection...
03:30:00 MQT: Connect failed to 192.168.1.50:1883, rc 5. Retry in 10 sec
03:30:11 MQT: Attempting connection...
03:30:11 MQT: Connect failed to 192.168.1.50:1883, rc 5. Retry in 10 sec
03:30:22 MQT: Attempting connection...
03:30:22 MQT: Connect failed to 192.168.1.50:1883, rc 5. Retry in 10 sec
03:30:33 MQT: Attempting connection...
03:30:33 MQT: Connect failed to 192.168.1.50:1883, rc 5. Retry in 10 se
The console of my MQTT server in HomeAssistant is this.
1574735604: New connection from 192.168.1.53 on port 1883.
1574735604: Socket error on client <unknown>, disconnecting.
1574735608: New connection from 192.168.1.51 on port 1883.
1574735608: Socket error on client <unknown>, disconnecting.
1574735615: New connection from 192.168.1.53 on port 1883.
1574735615: Socket error on client <unknown>, disconnecting.
1574735619: New connection from 192.168.1.51 on port 1883.
1574735619: Socket error on client <unknown>, disconnecting.
1574735626: New connection from 192.168.1.53 on port 1883.
1574735626: Socket error on client <unknown>, disconnecting.
I cannot figure out what I have done wrong.
Thanks in advance for the help.
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
1574771150: New connection from 192.168.1.53 on port 1883.
1574771150: Socket error on client <unknown>, disconnecting.
1574771160: New connection from 192.168.1.51 on port 1883.
[ERROR] Auth error with mqtt
1574771161: Socket error on client <unknown>, disconnecting.
1574771161: New connection from 192.168.1.53 on port 1883.
1574771172: New connection from 192.168.1.51 on port 1883.
1574771172: Socket error on client <unknown>, disconnecting.
1574771172: New connection from 192.168.1.53 on port 1883.
1574771183: New connection from 192.168.1.53 on port 1883.
1574771183: Socket error on client <unknown>, disconnecting.
1574771183: New connection from 192.168.1.51 on port 1883.
Sonoff1 config output.
