Hey, this is awesome. I am doing something very similar. I just started noticing a problem with mine and was wondering if you have had the same issue.
Basically when it is super hot out 90+ my relay stops working. I can see the LED trigger on the relay but it doesn’t fire. Once it cools back down it works. Any ideas? Have you seen this?
I’m using mqtt with a raspberry pi, and a Relay. My garage is often over 95 degrees but I haven’t experienced any problems with mine. Bad relay? ESP device having problems at high temps?
The esp is still responding to other commands, I have a servo setup on it as well to push a button my my remote start lol. I am thinking it could be a bad relay I guess. I’ll try swapping it out.
