MQTT garage door opener for "SOMMER pro+"
@jampez77 I was able to complete this using your guide! Many thanks!
It does work but it’s temperamental. Quite often I need to press open or close many times before relay clicks in. I’m constantly pinging wemos so for sure this is not related to WiFi. Also sometimes stop button acts like open/close and it doesn’t update the status when doors are open or closed?
Did you experience such a issues? I wonder if this is related to relay / wemos or there is some bug in the code?
I wonder if maybe you could add some logging future which could be check via http to see what signal wemos is sending, then it would be easier to understand if this is related to wemos or relay
I’ve had the open/close status issue once or twice before. For me this was because the status comes from an analog pin where the values are usually between 0 - 50. 0 being fully open and 50 fully closed.
The problem I have had in the past is that the open / closed threshold can vary a lot. Most of the time it reliably changes from open to closed at 15. Occasionally this shifts and I have to change the threshold to prevent the incorrect status changes.
You can try and change this threshold in the line 23, Helper.h file.
The only delays i’ve ever experienced I’ve put down to WiFi issues as my device is located far from an access point. As for the stop button, i’ve never really used it actually.
Sorry I couldn’t be more help but I will try and find some time to add in some logging over the weekend if I can find the time.
Release 1.3.1 - Added Debug Topic.
Created a debug topic that will send status input value received from the Conex along with the current open threshold.
By subscribing to the carDebugTopic you will be able to see the values used in the code that determines the open / closed state of the door.
I’ve also updated my version and changed from the Raspberry Pi Zero to an ESP8266 and esphome. Check it out here:
Any idea on how to purchase a conex? I live in the US and no one will ship here…
I contacted Sommer USA and they added the conex device to their store:
lol - now why didn’t i think of that! I’ve spoken to them before and never thought of asking - thank you very much. And the price is right too.
I’m going to attempt using this with a Zooz Zwave ZEN16 / 17 as I don’t like my controls using WiFi.
Hi, I’m considering getting one of these garage openers second hand and I was wondering if any of you have tried to get this working without the conex and/or output OC. From the limited pictures of these modules, they seem quite simple.
If anyone could add a few high res pictures of both sides of the modules, that would be great.
Determined it would cost me too much, instead I just hooked up a relay to an extra remote (same thing I did with my old garage door opener. I also output the 3V from my ESP8266 to power the remote and then just trigger open and closes off of that. Combine that with a simple door sensor and its been working great.
Just a quick update:
The Conex / Zooz Zen16 combo has worked fantastic. Door open / close using conex, door status using external sensor all through Zen16 using z-wave. One of my requirements was to not use WiFI and this worked perfectly.
@jspanitz You got a schema for me by coincidence?
I do have one - let me find it or draw it up again - give me a bit, holiday has got me too busy at the moment.
@jspanitz not needed anymore, but thanks for the effort! Meanwhile I’ve found the SommerESP solution as I wished to avoid the conex and output OC requirement. Check this:
Nice find. My only reservation is i prefer to have my door locks / controls on zwave or zigbee vs wifi. But I’m definitely looking at that project as an alternative if my zooz relay ever dies.
