I created a small Python script running on a Raspberry Pi Zero - yes there is better hardware, but I’m not a skilled programmer - to open and close my garage door which is operated by a garage door opener from the company “Sommer”. Here is my code. Feel free to try out and comment
I First tried to use an internal power supply (24V) with a step down converter, but the internal power is limited to 0.1A or so. So I use a standard power supply for raspberry.
Ah right. I did wonder/hope the internal power supply was good enough. that being said I’m planning on using a WeMos D1 Mini which draws less power than the Pi. Hopefully I can still use internal.
Thanks again for sharing! I also recognized this output module from Sommer but didn’t want to spent the money. So I decided to use a Xiaomi door sensor to keep track of the door status
In file included from c:\*****\documents\arduinodata\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.0-newlib4.0.0-gnu23-48f7b08\xtensa-lx106-elf\include\c++\10.2.0\stdlib.h:36,
from C:\*****\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.0\cores\esp8266/Arduino.h:27,
from sketch\garage_door_sensor.ino.cpp:1:
c:\*****\documents\arduinodata\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.0-newlib4.0.0-gnu23-48f7b08\xtensa-lx106-elf\include\c++\10.2.0\cstdlib:41:10: fatal error: bits/c++config.h: No such file or directory
41 | #include <bits/c++config.h>
compilation terminated.
exit status 1
Error compiling for board LOLIN(WEMOS) D1 mini (clone).
I’m not sure but it’s doesn’t appear to be related to the project itself. It could be something to do with your IDE setup?
The file path being different is a bit odd. Do you have both of these paths? or is one of them incorrect? from c:\*****\documents\arduinodata\ from C:\*****\Documents\ArduinoData\
anyway now I have problem with uploading it to WeMos
This is related to known problem on Mac’s with Ardunio not finding USB port
esptool.py v3.0
Serial port /dev/cu.Bluetooth-Incoming-Port
Connecting........_____....._____....._____....._____....._____....._____.....____Traceback (most recent call last):
File "/Users/Hotest/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/upload.py", line 66, in <module>
esptool.main(cmdline)
File "/Users/Hotest/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/esptool/esptool.py", line 3552, in main
esp.connect(args.before, args.connect_attempts)
File "/Users/Hotest/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/esptool/esptool.py", line 529, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
You have the incorrect port selected. If you go to Tools → Port and select your usb port. If you don’t know which one to choose then unplug your device, come off the menu, open it back up again and see which one has disappeared. Then plug it in a select that one.
