MQTT: Heihsamon (mqtt client) and Victron Cerbo (Bridge Mode) in parallel
I currently have heishamon (mqtt client) connected to the homeassistant mosquitto MQTT broker. Works like a charm as standalone.
Add-on configuration:
active: false
folder: mosquitto
Now I would like to add a Victron Cerbo GX System to HomeAssistant. To do so the Mqtt Broker have to be configured as bridge to mirror the data from the Cerbo GX Device.
https://community.home-assistant.io/t/victron-venus-os-with-mqtt-sensors-switches-and-numbers/527931
https://gist.github.com/KidA001/dc5584db340cf3ad513f9415b20ed5fa
To do so, the configuration has to be changed to:
active: true
But then the heishamon mqtt client data is not available any more.
Is it possible to configure the mosquitto broker as a bridge (for Victron Cerbo) and as normal broker (for heishamon) at the same time, to have the heishamon and Victron data available?
Thank you very much,
Armin
Just connect your heishamon to the home assistant mqtt broker. The cerbo gx will be bridged to the home assistant and all the topics will be visible.
