Preformatted textIn need of a little help I can not seam to get this to work I have motion sensors working with out issue but cant get this Aeotec Siren to work.
I’ve re posted the code below & yes the stat and topics are a copy past from the MQTT Smartthings Plugin for HASSIO I have a motion sensor working with out issue set up the same but cant get this working.
Don’t use spaces in a topic
A space is the natural enemy of each programmer, they often make it much harder to read and debug topics, when things are not going the way, they should be. So similar to the first one, only because something is allowed doesn’t mean it should be used. UTF-8 knows many different white space types, it’s pretty obvious that such uncommon characters should be avoided.
What @keithh666 is referring to is that your code has ” vs ". Likely an incorrect copy from somewhere.
