MQTT help. One switch is controlling two devices
I’m hoping this is straight forward and I’m missing something simple.
I’ve got two Tuya strips flashed with Sonoff 6.6 and assigned two different IPs and names in the Sonoff settings.
I only have one entity appear in MQTT integration and it controls both strips. If I turn on plug 1 the strip upstairs and downstairs turn on together.
Using hassio and the mqtt broker through the add ons.
What can I do to differentiate the two devices?
Thank you
They must be using the same mqtt topic then.
Thank you, I knew it would be easy. I wrongly thought setting the name as different would do it.
Sorted.
