Hi guys,
i’ve had some lights working through MQTT for a while and with the new mqtt format I changed to code to suit but now I’m getting a error message in the logs about the Schema line and i can’t find any info about it.
Will i be ok to delete this line or should i edit it to something else ?
ERROR (MainThread) [homeassistant.config] Invalid config for [sensor]: [schema] is an invalid option for [sensor]. Check: sensor->schema. (See /config/packages/h801_lights.yaml, line 152).
The sensor code …
mqtt:
- name: "Fish Tank LED"
schema: json
unique_id: fish_tank_leds
icon: "mdi:led-strip-variant"
state_topic: "LedStrip/Fish_tank_led/rgb/json_status"
command_topic: "LedStrip/Fish_tank_led/rgb/json_set"
availability_topic: "LedStrip/Fish_tank_led/active"
brightness: true
rgb: true
effect: true
effect_list: ["color_mode", "HDMI"]
qos: 0
optimistic: false
Steveuk:
The sensor code …
I believe you are saying that you have an MQTT light. So why are you coding it as an MQTT SENSOR?
you should change to this:
mqtt:
light:
Oh yeah of course i just copied and pasted from another configuration and didn’t spot that part.
thanks for that
Hi i changed to light instead and the warnings have gone now and the lights do work but there is this message in the logs do you know what it means ?
Manually configured MQTT light(s) found under platform key 'light', please move to the mqtt integration key, see https://www.home-assistant.io/integrations/light.mqtt/#new_format
finity
June 5, 2022, 10:04am
5
post your new latest config.
mqtt:
light:
schema: json
brightness: true
rgb: true
effect: true
qos: 0
optimistic: false
- name: "White"
schema: json
state_topic: "LedStrip/Fish_tank_led/white/json_status"
command_topic: "LedStrip/Fish_tank_led/white/json_set"
brightness: true
color_temp: true
qos: 0
optimistic: false
- name: "Combined"
schema: json
state_topic: "LedStrip/Fish_tank_led/combined/json_status"
command_topic: "LedStrip/Fish_tank_led/combined/json_set"
brightness: true
color_temp: true
rgb: true
effect: true
effect_list: ["white_mode", "color_mode", "both_mode", "HDMI"]
qos: 0
optimistic: false
finity
June 5, 2022, 10:12am
7
I’m not sure. It looks correct as far as I can see.
Are you sure those are the only mqtt lights you have configured?
Not that i’m aware of i’ll check through my files.
cheers
roschi02
(Robin)
June 7, 2022, 11:52am
9
I have zigbee2mqtt installed so i also had to change the zigbee2mqtt.yaml from
# Sensor for monitoring the bridge state
- platform: mqtt
name: Zigbee2MQTT Bridge state
state_topic: "zigbee2mqtt/bridge/state"
icon: mdi:router-wireless
# Sensor for Showing the Zigbee2MQTT Version
- platform: mqtt
state_topic: "zigbee2mqtt/bridge/config"
value_template: "{{ value_json.version }}"
icon: mdi:zigbee
# Sensor for Showing the Coordinator Version
- platform: mqtt
value_template: "{{ value_json.coordinator }}"
icon: mdi:chip
# Switch for enabling joining
switch:
- platform: mqtt
name: "Zigbee2MQTT Main join"
state_topic: "zigbee2mqtt/bridge/config/permit_join"
command_topic: "zigbee2mqtt/bridge/config/permit_join"
payload_on: "true"
payload_off: "false"
to
mqtt:
- name: Zigbee2MQTT Bridge state
- name: Zigbee2MQTT Version
icon: mdi:zigbee
- name: Coordinator Version
icon: mdi:chip
switch:
- name: "Zigbee2MQTT Main join"
payload_on: "true"
Thanks yeah that’s how I have it now.
Although I’m trying to change most things into the packages integration soi can just have 1 yaml file for the different kind of sensors.
