I created a new Home Assistant instance on my new NUC. It is set up in VM virtualbox.
The first thing I wanted to do is attach one lightbulb. With I flashed with Tasmota 9.2.0 (lite)
Preformed cmd command : setoption19 1 to be discoverable
I installed the Mosquitto broker and kept the configuration untouched
And added the MQTT integration and created A user (mqttuser) and password in Configuration > User .
Also installed the integration ‘ Tasmota’ don’t know if this was necessary.
If I look in the LOG I see that a new client is connected, this is the IP of my lightbulb, so should think this is OK. But I cant find this entity anywhere,…it is not mentioned under ‘ entities’ !??
<LOG:
1612534793: New connection from 192.168.2.29 on port 1883.
[INFO] found mqttuser on Home Assistant
1612534794: New client connected from 192.168.2.29 as DVES_973850 (p2, c1, k30, u'mqttuser').
