I have two wireless temperature sensors sending values in a single topic. Each sensor has it’s own ID. Now I’m trying to show each sensors temperature value separately, i.e., sensor ID 189, temperature 20 °C, sensor ID 116, temperature 25°C.
What I have so far is:
mqtt:
- name: "Siemens_GS"
state_topic: "Temp"
value_template: '{{ value_json }}'
json_attributes_topic: "Temp"
json_attributes_template: '{{ value_json | tojson }}'
This is the MQTT message (example):
{"time" : "2025-01-02 13:14:33", "model" : "Prologue-TH", "subtype" : 5, "id" : 189, "channel" : 1, "battery_ok" : 1, "temperature_C" : -18.600, "humidity" : 14, "button" : 0}
This gives both sensors values, but how can I select to receive only the values from one specific sensor?
Any idea / help very much appreciated.
