i’ve just installed a mqtt climate thermostat but i’ve noticed that this entity hasn’t an hysteresis values anymore.
How have you done to prevent continuos on/off heating when current temp is around the target temp?
My actual climate config is like this:
- platform: mqtt
retain: false
qos: 0
modes:
- heat
- 'off'
mode_state_topic: "termo/taverna/state"
mode_state_template: >-
{% set modes = { 'false':'off', 'true':'heat'} %}
{{ modes[value] if value in modes.keys() else 'off' }}
mode_command_topic: "termo/taverna/modeset"
current_temperature_topic: "termo/taverna/temp"
temperature_state_topic: "termo/taverna/TempSet"
temperature_command_topic: "termo/taverna/setpoint"
min_temp: 13
max_temp: 25.5
temp_step: 0.1
Thanks in advace,
Alessandro
