I’m trying to setup an MQTT HVAC entity over MQTT discovery.
Below is the configuration message that is sent to the homeassistant/climate/maxair/livingroom/config
topic:
"modes": [
"auto",
"off",
"heat",
"dry",
"fan_only"
"temp_unit":"C",
"force_update":true,
"availability_topic":"MaxAir/availability",
"away_mode_command_topic":"MaxAir/away/command",
"away_mode_state_topic":"MaxAir/away/state",
"unique_id":"maxair_livingroom",
"name":"MaxAir Living Room",
"mode_state_topic":"MaxAir/SC/mode",
"mode_command_topic":"MaxAir/SC/command",
"action_topic":"MaxAir/livingroom/state",
"action_template":"{{ value_json.hvac_action }}",
"aux_command_topic":"MaxAir/livingroom/aux_command",
"aux_state_topic":"MaxAir/livingroom/state",
"aux_state_template":"{{ value_json.aux_heat }}",
"current_temperature_topic":"MaxAir/livingroom/state",
"current_temperature_template":"{{ value_json.current_temperature }}",
"temperature_state_topic":"MaxAir/livingroom/state",
"temperature_state_template":"{{ value_json.temperature }}",
"temperature_command_topic":"MaxAir/livingroom/target_temp",
"json_attributes_topic":"MaxAir/livingroom/MySensor",
"device":{
"identifiers":[
"maxair_livingroom"
"model":"MySensor",
"manufacturer":"PiHome"
Everything works well apart from the mode command. When I try to change the mode from the lovelace thermostat card no message gets published on the MaxAir/SC/command
topic. Is there something else needed for the command message to be sent?
