Premise: I’m new to MQTT integration with HA, I’ve read many questions on the community that have helped me so far but atm I’m stuck…
I have some MC6 HVAC thermostat that I’d like to integrate in HA via MQTT.
The problem is that this device sends values and receive command using a single MQTT topic where it publishes and subscribes to.
The topic is updData/MACADDRESS
The MQTT paload is a json:
{"msgid":18,
"mac":"MACADDRESS",
"version":4,
"temp":265, <---multiplied by 10
"humi":500, <---multiplied by 10
"settemp":250, <---multiplied by 10
"mode":2,
"onoff":1,
"frost":70,"
"standby":2,
"fan":2,"
timezone":13,
"prog":0,
"temp_prog":{}
I have a MQTT climate platform configured and it works readings both the current temp and the desired temp, but I’m not able to send temp variation to the device.
- climate:
object_id: mc6_hvac
modes:
- "cool"
- "heat"
- "fan_only"
- "drying"
- "off"
mode_state_topic: "updData/MACADDRESS"
mode_state_template: "{{ value_json.node }}"
fan_modes:
- "Auto"
- "High"
- "Medium"
- "Low"
fan_mode_state_topic: "updData/MACADDRESS"
fan_mode_state_template: "{{ value_json.fan }}"
min_temp: 16
max_temp: 30
temp_step: 0.1
current_temperature_topic: "updData/MACADDRESS"
current_temperature_template: "{{ value_json.temp|float / 10 }}"
temperature_state_topic: "updData/MACADDRESS"
temperature_state_template: "{{ value_json.settemp|float / 10 }}"
current_humidity_topic: "updData/MACADDRESS"
current_humidity_template: "{{ value_json.humi|float / 10 }}"
precision: 0.1
retain: false
qos: 0
How can I set the returning json to be publised as the thermostat wants it.
Another problem are the operating mode transcoding: the device sends numbers (1 cool, 2 heat, 3 vent, 4 auto) but HA tries to send “cool” or “heat”…
TY in advance
Solved.
mqtt:
- climate:
object_id: mc6_1
unique_id: mc6_1
# MC6 gets updates immediately but sends status messages only after some minutes, so it's better to update the UI optimistically
optimistic: true
# MC6 in MQTT config supports only 4 modes, cooling,heating,fan only and dehumidifying
# MC6 discard the dry mode when sent by mqtt, it may report it's status if the dehumid settings is enabled on the thermostat (not tested)
modes:
- "cool"
- "heat"
- "fan_only"
- "dry"
mode_state_topic: "updData/MACADDRESS-lowercase"
# from MC6 manual: mode(1 cool, 2 heat, 3 vent, 4 auto), but in my thermostat the Auto fnction is replaced by Dehumid
mode_state_template: >-
{% if value_json.mode == 1 %}
cool
{% elif value_json.mode == 2 %}
heat
{% elif value_json.mode == 3 %}
fan_only
{% elif value_json.mode == 4 %}
dry
{% endif %}
mode_command_topic: "MACADDRESS-lowercase"
mode_command_template: >-
{% if (value | string) == "cool" %}
{ "mode": 1 }
{% elif (value | string) == "heat" %}
{ "mode": 2 }
{% elif (value | string) == "fan_only" %}
{ "mode": 3 }
{% elif (value | string) == "dry" %}
{ "mode": 4 }
{% endif %}
# from MC6 manual: fan speed(1 high, 2 medium, 3 low, 4 auto)
fan_modes:
- "High"
- "Medium"
- "Low"
- "Auto"
fan_mode_state_topic: "updData/MACADDRESS-lowercase"
fan_mode_state_template: >-
{% if value_json.fan == 1 %}
High
{% elif value_json.fan == 2 %}
Medium
{% elif value_json.fan == 3 %}
Low
{% elif value_json.fan == 4 %}
Auto
{% endif %}
fan_mode_command_topic: "MACADDRESS-lowercase"
fan_mode_command_template: >-
{% if value == "High" %}
{ "fan":3 }
{% elif value == "Medium" %}
{ "fan":2 }
{% elif value == "Low" %}
{ "fan":1 }
{% elif value == "Auto" %}
{ "fan":4 }
{% endif %}
min_temp: 5
max_temp: 30
temp_step: 0.5
current_temperature_topic: "updData/MACADDRESS-lowercase"
# dividing by 10 when reading the settings
current_temperature_template: "{{ value_json.temp | float / 10 }}"
temperature_state_topic: "updData/MACADDRESS-lowercase"
temperature_state_template: "{{ value_json.settemp | float / 10 }}"
temperature_command_topic: "MACADDRESS-lowercase"
# multiplying by 10 when writing the settings
temperature_command_template: "{ \"settemp\":{{ (value * 10) | int }} }"
current_humidity_topic: "updData/MACADDRESS-lowercase"
current_humidity_template: "{{ value_json.humi | int / 10 }}"
precision: 0.1
retain: false
qos: 1
- switch:
unique_id: mc6_1_switch_onoff
object_id: mc6_1_switch_onoff
name: "MC6-1 Switch-onoff"
optimistic: false
state_on: "ON"
state_off: "OFF"
value_template: >-
{% if value_json.onoff == 1 %}
"ON"
{% elif value_json.onoff == 2 %}
"OFF"
{% endif %}
payload_on: '{"onoff":1 }'
payload_off: '{"onoff":2 }'
template:
- sensor:
- name: "MC6-1-Humi"
device_class: humidity
unit_of_measurement: '%'
state: "{{ state_attr('climate.mc6_hvac', 'current_humidity') | float }}"
