Hi All,
I have a Midea AC unit which until a couple months back worked flawlessly via WiFi. Except now it doesn’t, and since nobody Hase found a solution to he problem. I decided to create my own solution with an ESP8266 controller and an IR led.
So far I have everything working, very smoothly. I configured the climate component to use MQTT as you can see below:
climate:
- platform: mqtt
modes:
- "off"
- "auto"
- "cool"
- "heat"
- "dry"
- "fan_only"
swing_modes:
- "on"
- "off"
fan_modes:
- "high"
- "medium"
- "low"
- "auto"
power_command_topic: "woonkamer/ac/power/set"
mode_command_topic: "woonkamer/ac/mode/set"
temperature_command_topic: "woonkamer/ac/temperature/set"
fan_mode_command_topic: "woonkamer/ac/fan/set"
swing_mode_command_topic: "woonkamer/ac/swing/set"
current_temperature_topic: "woonkamer/ac/temperature/room"
precision: 1.0
Now I have a Nuba casa account so I can acces everything outside the house. I also exposed the climate.woonkamer to google assistant so I can control it with my google home device.
But After syncing devices it is displayed as an thermostat, I only have the option to set the mode to heating/cooling, On/Off.
Is there A way to display it as an actual AC unit so I can use most if not all of the options.
regards Jordy
Video of the esp8266 working: https://www.facebook.com/jordy.kleian/videos/10223014299851867/
Video of limited voice control:
