Hi, I did a simple sudo apt-get update and apt-get upgrade today an now I have the following error in the logs
2017-06-03 21:29:48 ERROR (MainThread) [homeassistant.setup] Error during setup of component mqtt
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/setup.py", line 185, in _async_setup_component
result = yield from component.async_setup(hass, processed_config)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/mqtt/__init__.py", line 380, in async_setup
success = yield from hass.data[DATA_MQTT].async_connect()
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/mqtt/__init__.py", line 490, in async_connect
None, self._mqttc.connect, self.broker, self.port, self.keepalive)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/home/homeassistant/.homeassistant/deps/paho/mqtt/client.py", line 700, in connect
return self.reconnect()
File "/home/homeassistant/.homeassistant/deps/paho/mqtt/client.py", line 822, in reconnect
sock = socket.create_connection((self._host, self._port), source_address=(self._bind_address, 0))
File "/usr/lib/python3.4/socket.py", line 509, in create_connection
raise err
File "/usr/lib/python3.4/socket.py", line 500, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
so, obviously mqtt is not working and I really do not know why and how to solve this. Can anyone help me sort this out ? I already try rebooting the pi and restarting HASS. And I really would like to find a better solution than to wipe everything and do a fresh install.
