I am having trouble setting up this integration with the UI. I am going through the UI when trying to add this integration. Based off of the information here: [https://www.home-assistant.io/integrations/mqtt] the integration is asking for the IP address. Seems basic, but I am stuck. I have tried. 192.168.1.8 and http://192.168.1.8, I have triple checked the username and password.
Can you connect with a third party mqtt broker ? E.g. MQTT Explorer, MQTT Fx ?
If you installed zwave2mqtt, did you also install the mosquitto add-on ?
