MQTT Integration doesn't create entity after re-pairing with zigbee2mqtt
Hi, I have an Aqara motion sensor and this sensor has been paired with zigbee2mqtt before it lost connection with zigbee2mqtt recently.
After changing the battery, I force removed it using zigbee2mqtt assistant and zigbee2mqtt log showing it has been successfully removed. Then, i factory reset the Aqara motion sensor.
After that, I’m trying to re-pair it again with zigbee2mqtt and the log said it successfully interviewed and the devices is broadcasting to zigbee2mqtt.
However, there is no entity created in MQTT integration. Tried repeat the process again and it’s still the same.
Any idea what’s wrong with it? I’m currently running with core 0.115.2 and zigbee2mqtt 0.10.0.
You are running a very old installation of Zigbee2mqtt. The current version is 1.15.0
Maybe try upgrading.
Is there a way to update to a particular instead the latest release? I noticed there is a breaking changes in 1.14.4.1 which it renames the entity. I’m thinking to update to 1.14.4 only.
Thanks.
