Hy there,
I had HA running with MQTT to IOBroker with no problems. I had all my Tasmota devices in it. That worked fine.
Now I changed something (Never change a running system!) - and it stopped working.
I installed a Mosquitto server on a VM and redirected all my Tasmota devices to that. The values land there, I see them in my InfluxDB and in MQTT Explorer. So this is working.
Then I deleted the MQTT integration in Home Assistant and installed it again. That only showed 5 devices instead of more than 30. I did not see any speciality in data format, so I uninstalled MQTT again, reinstalled it and … again not working
So I deleted that homeassistant tree in Mosquitto and deinstalled and installed MQTT integration again. That had a effect - now I do not see any discovered items
The homeassistant tree in Mosquitto is also not growing again. It only has the status in it.
When I start the listener in MQTT, it shows all items which I need but will not autodiscover them.
I think there must be a file where he stores identities that he already knows and then skips them in autodiscovery. Am I right?
How can I recover that?
Best regards,
Roger
EDIT: Cleaning up in config/.storage/core.device_registry did not help
EDIT2: Doing setoption19 1 on the Tasmota devices did not change anything.
