MQTT integration not working on HA 2024.1.1 dockerized
Hello everyone.
I setup a MQTT integration on my 2024.1.1 docker-HA running on a RPi.
The integration setup and initial configuration work fine.
If I try then the integration, click on it → configuration and then try to publish a message to a topic it fails , and HA displays the message
Service mqtt.publish not found.
Does anyone have an idea of why this happens?
Do you see anything in the logs ?
You would get this if the mqtt integration did not load.
The logs do not contain any reference to an error of the mqtt integration. I checked under settimgs → system → full logs
At setup time of the integration, if I check the mqtt broker logs, I see that there is communication between the parties and the setup connection is successful. Not sure if this helps.
I was able to fix the situation.
Apparently it was enough to (hard) restart home assistant from docker perspective, instead of restarting it from the web app.
Now everything works fine
