MQTT integration - problem adding device - yaml config vs discovery
Anyone had success converting MQTT discovery to manual sensor yaml entities?
I am able to add the same sensor, yet with yaml the device discovery is not working and the sensors lack the “related” settings, while with mqtt discovery device is added as well.
Sensor added, device added
alias: MQTT manual add
sequence:
  - service: mqtt.publish
      topic: homeassistant/switch/computherm_3/config
      retain: true
      payload: |-
          "name": "computherm-3-extra",
          "uniq_id": "wifito868gw_computherm_ABCDEF",
          "stat_t": "wifito868gw/computherm/ABCDEF/status",
          "cmd_t": "wifito868gw/computherm/ABCDEF/control",
          "avty_t": "wifito868gw/availability",
          "icon": "mdi:thermometer-lines",
          "device": {
              "identifiers": ["(ESP8266MOD, wifito868gw)"],
              "manufacturer": "WEMOS",
              "model": "D1 Mini",
              "name": "wifito868gw"
core\homeassistant\components\mqtt\discovery.py | async_discovery_message_received | if CONF_DEVICE in payload is called
→ async_forward_entry_setup → async_setup
Sensor added, device is not added
- platform: mqtt
  name: "wifito868gw Temperature"
  unit_of_measurement: "°C"
  state_topic: "wifito868gw/sensor/status"
  icon: "mdi:temperature-celsius"
  availability_topic: "wifito868gw/availability"
  device_class: "temperature"
  state_class: "measurement"
  value_template: "{{ value_json.temp }}"
  device:
    connections: [["mac", "98:CD:XX:XX:XX:XX"]]
    identifiers: ["(ESP8266MOD, wifito868gw)"]
    manufacturer: "WEMOS"
    model: "D1 Mini"
core\homeassistant\components\mqtt\sensor.py | async def async_setup_entry is called
