I have been using HA and MQTT for a couple of years without problems. Last week the MQTT integration have stopped working and I’m not getting data nor can I send MQTT from HA.
Mosquitto broker is running fine and I can see messages using mqtt-explorer
The log shows endless amounts of wierds connection:
2024-07-31 13:33:02: New connection from 172.30.32.2:59262 on port 1883.
2024-07-31 13:33:02: Client closed its connection.
HA usses enp0s3: 192.168.0.xxxx
eth0 is 172.30.33.2 - Which seems wrong and perhaps the MQTT integration is transmitting on the wrong ip address because a restart gave this:
[13:47:23] INFO: Successfully send discovery information to Home Assistant.
[13:47:24] INFO: Successfully send service information to the Supervisor.
2024-07-31 13:47:45: New connection from 192.168.0.200:33588 on port 1883.
2024-07-31 13:47:45: New client connected from 192.168.0.200:33588 as nodered_1473296315633694 (p2, c1, k60, u’xxxx’).
2024-07-31 13:48:26: New connection from 172.30.32.1:45771 on port 1883.
2024-07-31 13:48:26: New client connected from 172.30.32.1:45771 as 5fja3EecTaUr4tqZmLhZZD (p2, c1, k60, u’xxxx’).
And then the rest is from 172.30.32.1:45771
Any ideas for solutions or how to troubleshoot this?
