So … I broke my zigBee-2-MQTT integration and now I need to setup it up again.
I’ve got my ZigBee-2-MQTT setup on a RaspberryPi in a docker installation.
I can verify that z2m talks to my MQTT-broker in HomeAssistant, but I don’t see any trace of my devices from z2m in HA.
My MQTT integration conf..
Discoveryprefix - homeassistant
Enable Birth mess. CHECK
Birth mess topic - homeassistant/status
Enable Will mess. CHECK
Will mess topic - homeassistant/status
z2m conf. (Hass integration)
Homeassistant discovery topic - homeassistant
Home Assistant status topic - homeassistant/status
z2m conf. (MQTT)
Base Topic - homeassistant
A common problem is that you’ve set the frontend url value in Zigbee2MQTT to something that’s not a valid URL (eg 192.168.0.42:8080 instead of http://192.168.0.42:8080) - and if that’s the case it’ll be quite obvious in Home Assistant’s log.
