[MQTT-IO] Permission Error i2c
On Raspberry Pi 3 (Home Assistant OS 10.1), i2c enabled, MQTT-IO addon installed. I’ve got an error when try to starting it :
PermissionError: [Errno 1] Operation not permitted: '/dev/i2c-0'
I assume the MQTT-IO addon has no “right to use” i2c hardware…
The config.yml used :
mqtt:
  host: localhost
  port: 1883
  user: ****
  password: ****
  ha_discovery:
    enabled: yes
  topic_prefix: home/meteo
sensor_modules:
  - name: bme280_sensor
    module: bme280
    i2c_bus_num: 0
    chip_addr: 0x76
sensor_inputs:
  - name: temperature
    module: bme280_sensor
    interval: 30
    digits: 1
    type: temperature
    ha_discovery:
      device_class: temperature
      unit_of_measurement: "°C"
  - name: pressure
    interval: 30
    digits: 1
    type: pressure
    ha_discovery:
      device_class: pressure
      unit_of_measurement: "hPa"
The full log from the addon :
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
 Add-on: MQTT IO
 Expose GPIO modules and digital sensors via MQTT for remote control and monitoring.
 Add-on version: 0.2.1
 You are running the latest version of this add-on.
 System: Home Assistant OS 10.1  (aarch64 / raspberrypi3-64)
 Home Assistant Core: 2023.5.4
 Home Assistant Supervisor: 2023.05.dev2301
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
Log level is set to DEBUG
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service mqtt-io: starting
s6-rc: info: service mqtt-io successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[07:31:17] INFO: Starting MQTT IO...
2023-05-24 07:31:32 mqtt_io.__main__ [ERROR] MqttIo crashed!
  File "/usr/lib/python3.10/site-packages/mqtt_io/__main__.py", line 107, in main
    mqtt_gpio.run()
  File "/usr/lib/python3.10/site-packages/mqtt_io/server.py", line 1242, in run
    self._init_sensor_modules()
  File "/usr/lib/python3.10/site-packages/mqtt_io/server.py", line 255, in _init_sensor_modules
    self.sensor_modules[sens_config["name"]] = _init_module(
  File "/usr/lib/python3.10/site-packages/mqtt_io/server.py", line 128, in _init_module
    return module_class(module_config)
  File "/usr/lib/python3.10/site-packages/mqtt_io/modules/sensor/__init__.py", line 22, in __init__
    self.setup_module()
  File "/usr/lib/python3.10/site-packages/mqtt_io/modules/sensor/bme280.py", line 38, in setup_module
    self.bus = SMBus(self.config["i2c_bus_num"])
  File "/usr/lib/python3.10/site-packages/smbus2/smbus2.py", line 280, in __init__
    self.open(bus)
  File "/usr/lib/python3.10/site-packages/smbus2/smbus2.py", line 310, in open
    self.fd = os.open(filepath, os.O_RDWR)
  File "/usr/lib/python3.10/runpy.py", line 196, in _run_module_as_main
    return _run_code(code, main_globals, None,
  File "/usr/lib/python3.10/runpy.py", line 86, in _run_code
    exec(code, run_globals)
  File "/usr/lib/python3.10/site-packages/mqtt_io/__main__.py", line 115, in <module>
    main()
    mqtt_gpio.run()
    self.setup_module()
    self.open(bus)
[07:31:33] INFO: Service MQTT IO exited with code 1 (by signal 0)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service mqtt-io: stopping
s6-rc: info: service mqtt-io successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Thanks for any help !
