Im trying to get Aircookies WLED connecting with HA using the MQTT add-on. I have MQTT setup, and in the logs i can see my WLED devices showing up. In my wled i have the mqtt broker address as my hassio ip. I then installed mqtt explorer and i was expecting that when i make any changes in wled it should pick up the mqtt messages but im seeing nothing.
At a total loss why its not working, im presuming i have something setup wrong with my mqtt. Any thoughts?
lolouk44
(lolouk44)
September 12, 2019, 6:31pm
2
If you could share your config, it would help.
At least the MQTT definition bit and where/how you defined the WLED in HA
Ok actually managed to get that working now, seems there was an issue with mqtt so had to reinstall it.
Something new though, i have added the light manually in my config.yaml file as a mqtt light, but unless im getting the topic names wrong its not sending the messages. Since im using credentials on mqtt do i need to add that in the config? at the moment its like this
light:
- platform: mqtt
command_topic: "wled/mushroom"
brightness_command_topic: "wled/mushroom"
rgb_command_topic: "wled/mushroom/col"
rgb_command_template: "{{ '#%02x%02x%02x' | format(red, green, blue)}}"
effect_command_topic : "wled/mushroom/api"
aidbish
(Adrian)
September 14, 2019, 1:44pm
4
this is mine
platform: mqtt
state_topic: "gardenlights/all/g"
command_topic: "gardenlights/all/api"
rgb_state_topic: "gardenlights/all/c"
rgb_command_topic: "gardenlights/all/col"
brightness_command_topic: "gardenlights/all"
brightness_state_topic: "gardenlights/all/g"
brightness_value_template: "{{value }} "
rgb_value_template: "{{ value[1:3] | int(base=16) }},{{ value[3:5] | int(base=16) }},{{ value[5:7]| int(base=16) }}"
qos: 0
optimistic: true
on_command_type: "first"
payload_on: "T=1"
payload_off: "T=0"
effect_list:
- "[FX=00] STATIC"
- "[FX=01] BLINK"
- "[FX=02] BREATH"
- "[FX=03] COLOR_WIPE"
- "[FX=04] COLOR_WIPE_RANDOM"
- "[FX=05] RANDOM_COLOR"
- "[FX=06] COLOR_SWEEP"
- "[FX=07] DYNAMIC"
- "[FX=08] RAINBOW"
- "[FX=09] RAINBOW_CYCLE"
- "[FX=10] SCAN"
- "[FX=11] DUAL_SCAN"
- "[FX=12] FADE"
- "[FX=13] THEATER_CHASE"
- "[FX=14] THEATER_C_RAINBOW"
- "[FX=15] RUNNING_LIGHTS"
- "[FX=16] SAW"
- "[FX=17] TWINKLE"
- "[FX=18] DISSOLVE"
- "[FX=19] DISSOLVE_RANDOM"
- "[FX=20] SPARKLE"
- "[FX=21] FLASH_SPARKLE"
- "[FX=22] HYPER_SPARKLE"
- "[FX=23] STROBE"
- "[FX=24] STROBE_RAINBOW"
- "[FX=25] MULTI_STROBE"
- "[FX=26] BLINK_RAINBOW"
- "[FX=27] ANDROID"
- "[FX=28] CHASE_COLOR"
- "[FX=29] CHASE_RANDOM"
- "[FX=30] CHASE_RAINBOW"
- "[FX=31] CHASE_FLASH"
- "[FX=32] CHASE_FLASH_RANDOM"
- "[FX=33] CHASE_RAINBOW_WHITE"
- "[FX=34] COLORFUL"
- "[FX=35] TRAFFIC_LIGHT"
- "[FX=36] COLOR_SWEEP_RANDOM"
- "[FX=37] RUNNING_COLOR"
- "[FX=38] RUNNING_RED_BLUE"
- "[FX=39] RUNNING_RANDOM"
- "[FX=40] LARSON_SCANNER"
- "[FX=41] COMET"
- "[FX=42] FIREWORKS"
- "[FX=43] RAIN"
- "[FX=44] MERRY_CHRISTMAS"
- "[FX=45] FIRE_FLICKER"
- "[FX=46] GRADIENT"
- "[FX=47] LOADING"
- "[FX=48] DUAL_COLOR_WIPE_IN_OUT"
- "[FX=49] DUAL_COLOR_WIPE_IN_IN"
- "[FX=50] DUAL_COLOR_WIPE_OUT_OUT"
- "[FX=51] DUAL_COLOR_WIPE_OUT_IN"
- "[FX=52] CIRCUS_COMBUSTUS"
- "[FX=53] HALLOWEEN"
- "[FX=54] TRICOLOR_CHASE"
- "[FX=55] TRICOLOR_WIPE"
- "[FX=56] TRICOLOR_FADE"
- "[FX=57] LIGHTNING"
- "[FX=58] ICU"
- "[FX=59] MULTI_COMET"
- "[FX=60] DUAL_LARSON_SCANNER"
- "[FX=61] RANDOM_CHASE"
- "[FX=62] OSCILLATE"
- "[FX=63] PRIDE_2015"
- "[FX=64] JUGGLE"
- "[FX=65] PALETTE"
- "[FX=66] FIRE_2012"
- "[FX=67] COLORWAVES"
- "[FX=68] BPM"
- "[FX=69] FILLNOISE8"
- "[FX=70] NOISE16_1"
- "[FX=71] NOISE16_2"
- "[FX=72] NOISE16_3"
- "[FX=73] NOISE16_4"
- "[FX=74] COLORTWINKLE"
- "[FX=75] LAKE"
- "[FX=76] METEOR"
- "[FX=77] METEOR_SMOOTH"
- "[FX=78] RAILWAY"
- "[FX=79] RIPPLE"
effect_command_topic: "gardenlights/all/api"
effect_state_topic: "gardenlights/all/api"
effect_value_template: "{{ value }}"
Thanks, i tried using your config but i get a bad indentation error. Not sure how to solve that?
There was a missing quote mark at the end.
Sat Sep 14 2019 15:25:38 GMT+0100 (British Summer Time)
"Sat Sep 14 2019 15:25:38 GMT+0100 (British Summer Time)
Component error: rgb_command_topic - Integration rgb_command_topic not found.
Component error: brightness_command_topic - Integration brightness_command_topic not found.
Component error: effect_value_template - Integration effect_value_template not found.
Component error: optimistic - Integration optimistic not found.
Component error: effect_command_topic - Integration effect_command_topic not found.
Component error: state_topic - Integration state_topic not found.
Component error: on_command_type - Integration on_command_type not found.
Component error: brightness_value_template - Integration brightness_value_template not found.
Component error: rgb_state_topic - Integration rgb_state_topic not found.
Component error: rgb_value_template - Integration rgb_value_template not found.
Component error: rgb_command_template - Integration rgb_command_template not found.
Component error: brightness_state_topic - Integration brightness_state_topic not found.
Component error: name - Integration name not found.
Component error: platform - Integration platform not found.
Component error: payload_off - Integration payload_off not found.
Component error: qos - Integration qos not found.
Component error: effect_state_topic - Integration effect_state_topic not found.
Component error: command_topic - Integration command_topic not found.
Component error: effect_list - Integration effect_list not found.
Component error: payload_on - Integration payload_on not found."
I got this now though, do i need to define those somewhere else?
lebherz
(Rene Lebherz)
September 30, 2019, 10:58pm
8
only in lovelace.ui as entity or light(entity):
I don’t use LoveLace but this might be interesting:
@lebherz , how did you get the second gui? Mine looks like the first one using light card, missing the color options and the effects dropdown, which I did put into the lights.yaml as per one of the previous posts.
lebherz
(Rene Lebherz)
October 30, 2019, 11:09pm
12
when you click the 3 vertical dots the second gui appeaers. turn on the light, and the wheel and the effect selection appears.
here is my only entry in HA. (in the configuration.yaml.
light:
- platform: mqtt
state_topic: "wled/wohnzimmer/g"
command_topic: "wled/wohnzimmer/api"
rgb_state_topic: "wled/wohnzimmer/c"
rgb_command_topic: "wled/wohnzimmer/col"
brightness_command_topic: "wled/wohnzimmer"
brightness_state_topic: "wled/wohnzimmer/g"
qos: 2
retain: true
optimistic: true
payload_on: "T=1"
payload_off: "T=0"
effect_list:
- "[FX=00] STATIC"
- "[FX=01] BLINK"
- "[FX=02] BREATH"
- "[FX=07] DYNAMIC"
- "[FX=08] RAINBOW"
- "[FX=10] SCAN"
- "[FX=12] FADE"
- "[FX=16] SAW"
- "[FX=17] TWINKLE"
- "[FX=20] SPARKLE"
- "[FX=23] STROBE"
- "[FX=27] ANDROID"
- "[FX=41] COMET"
- "[FX=43] RAIN"
- "[FX=47] LOADING"
- "[FX=58] ICU"
- "[FX=64] JUGGLE"
- "[FX=65] PALETTE"
- "[FX=68] BPM"
- "[FX=75] LAKE"
- "[FX=76] METEOR"
- "[FX=78] RAILWAY"
- "[FX=79] RIPPLE"
- "[FX=80] TWINKLEFOX"
- "[FX=81] Twinklecat"
- "[FX=82] Halloween Eyes"
effect_command_topic: "wled/wohnzimmer/api"
effect_state_topic: "wled/wohnzimmer/api"
regards
rene
There’s no manual adding needed as the wled will be auto discovered by hass
Vendo232
(Vendo232)
November 8, 2019, 4:54pm
14
How do you call WLED entity in automation? I would like to turn on my WS2812 for 1 min and define specific Effect. How to do it?
