I realize the MQTT logs isn’t showing up in chronological order !!
See below the full log for
MQTT
s6-rc: info: service legacy-services successfully started
[11:47:29] INFO: Starting mosquitto MQTT broker...
2024-06-10 11:47:29: Warning: Mosquitto should not be run as root/administrator.
2024-06-10 11:47:29: mosquitto version 2.0.18 starting
2024-06-10 11:47:29: Config loaded from /etc/mosquitto/mosquitto.conf.
2024-06-10 11:47:29: Loading plugin: /usr/share/mosquitto/go-auth.so
2024-06-10 11:47:29: ├── Username/password checking enabled.
2024-06-10 11:47:29: ├── TLS-PSK checking enabled.
2024-06-10 11:47:29: └── Extended authentication not enabled.
2024-06-10 11:47:29: Opening ipv4 listen socket on port 1883.
2024-06-10 11:47:29: Opening ipv6 listen socket on port 1883.
2024-06-10 11:47:29: Opening websockets listen socket on port 1884.
2024-06-10 11:47:29: mosquitto version 2.0.18 running
2024-06-10 11:47:29: New connection from 127.0.0.1:46576 on port 1883.
2024-06-10 11:47:29: Client <unknown> disconnected due to protocol error.
[11:47:30] INFO: Successfully send discovery information to Home Assistant.
[11:47:30] INFO: Successfully send service information to the Supervisor.
2024-06-10 12:17:30: Saving in-memory database to /data//mosquitto.db.
2024-06-10 12:18:35: New connection from 172.30.33.4:47138 on port 1883.
2024-06-10 12:18:35: New client connected from 172.30.33.4:47138 as mqttjs_23eafec6 (p2, c1, k60, u'mqtt').
2024-06-10 12:19:47: New connection from 172.30.32.1:33429 on port 1883.
2024-06-10 12:19:47: New client connected from 172.30.32.1:33429 as 1Bz3iuI4FOw8q9PKy6XgMV (p2, c1, k60, u'homeassistant').
2024-06-10 12:19:47: Client 1Bz3iuI4FOw8q9PKy6XgMV disconnected.
2024-06-10 12:19:47: New connection from 172.30.32.1:59361 on port 1883.
2024-06-10 12:19:47: New client connected from 172.30.32.1:59361 as 0VVywc9XkemNLSsGHC9DNA (p2, c1, k60, u'homeassistant').
2024-06-10 12:21:15: New connection from 172.30.32.1:60329 on port 1883.
2024-06-10 12:21:15: Client 3IUbOc2DqkXKuyYKfvDjFI disconnected, not authorised.
2024-06-10 12:21:53: New connection from 172.30.32.1:43809 on port 1883.
2024-06-10 12:21:53: New client connected from 172.30.32.1:43809 as 5RR6kUO1toWo1avpIAZVUZ (p2, c1, k60, u'mqtt').
2024-06-10 12:21:53: Client 5RR6kUO1toWo1avpIAZVUZ disconnected.
2024-06-10 12:22:02: New connection from 172.30.32.1:42399 on port 1883.
2024-06-10 12:22:02: New client connected from 172.30.32.1:42399 as 4BuA5QxrqenQzy2l8WpowG (p2, c1, k60, u'mqtt').
2024-06-10 12:23:35: Client 0VVywc9XkemNLSsGHC9DNA has exceeded timeout, disconnecting.
2024-06-10 12:25:53: Client 4BuA5QxrqenQzy2l8WpowG closed its connection.
2024-06-10 12:26:01: New connection from 172.30.32.1:39117 on port 1883.
2024-06-10 12:26:01: New client connected from 172.30.32.1:39117 as 65Lr9hwI3vU7wl9ty6dAlX (p2, c1, k60, u'mqtt').
2024-06-10 12:30:13: Client mqttjs_23eafec6 disconnected.
2024-06-10 12:30:20: New connection from 172.30.33.4:43298 on port 1883.
2024-06-10 12:30:20: New client connected from 172.30.33.4:43298 as mqttjs_95a8c186 (p2, c1, k60, u'mqtt').
s6-rc: info: service legacy-services: stopping
[10:41:35] INFO: Service restart after closing
2024-06-10 12:41:35: mosquitto version 2.0.18 terminating
time="2024-06-10T12:41:35+02:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": dial tcp 127.0.0.1:80: connect: connection refused"
time="2024-06-10T12:41:35+02:00" level=error msg="POST error: Post \"http://127.0.0.1:80/acl\": dial tcp 127.0.0.1:80: connect: connection refused"
time="2024-06-10T12:41:35+02:00" level=error msg="Post \"http://127.0.0.1:80/superuser\": dial tcp 127.0.0.1:80: connect: connection refused"
2024-06-10 12:41:35: Saving in-memory database to /data//mosquitto.db.
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[13:08:29] INFO: SSL is not enabled
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
[13:08:29] INFO: Starting NGINX for authentication handling...
[13:08:30] INFO: Starting mosquitto MQTT broker...
2024-06-10 13:08:30: Warning: Mosquitto should not be run as root/administrator.
2024-06-10 13:08:30: mosquitto version 2.0.18 starting
2024-06-10 13:08:30: Config loaded from /etc/mosquitto/mosquitto.conf.
2024-06-10 13:08:30: Loading plugin: /usr/share/mosquitto/go-auth.so
2024-06-10 13:08:30: ├── Username/password checking enabled.
2024-06-10 13:08:30: ├── TLS-PSK checking enabled.
2024-06-10 13:08:30: └── Extended authentication not enabled.
2024-06-10 13:08:30: Opening ipv4 listen socket on port 1883.
2024-06-10 13:08:30: Opening ipv6 listen socket on port 1883.
2024-06-10 13:08:30: Opening websockets listen socket on port 1884.
2024-06-10 13:08:30: mosquitto version 2.0.18 running
2024-06-10 13:08:30: New connection from 127.0.0.1:39726 on port 1883.
2024-06-10 13:08:30: Client <unknown> disconnected due to protocol error.
[13:08:30] INFO: Successfully send discovery information to Home Assistant.
[13:08:30] INFO: Successfully send service information to the Supervisor.
2024-06-10 13:09:15: New connection from 172.30.32.1:42997 on port 1883.
2024-06-10 13:09:15: New client connected from 172.30.32.1:42997 as 4LlZ3uNpa21M14pnrQJ3q9 (p2, c1, k60, u'homeassistant').
2024-06-10 13:09:15: Client 4LlZ3uNpa21M14pnrQJ3q9 disconnected.
2024-06-10 13:09:15: New connection from 172.30.32.1:38515 on port 1883.
2024-06-10 13:09:15: New client connected from 172.30.32.1:38515 as 6HwKZdG9tJiDNwNnTFGExV (p2, c1, k60, u'homeassistant').
2024-06-10 13:12:23: New connection from 172.30.33.4:56112 on port 1883.
2024-06-10 13:12:23: New client connected from 172.30.33.4:56112 as mqttjs_51cdfd25 (p2, c1, k60, u'mqtt').
2024-06-10 13:14:20: New connection from 172.30.32.1:54785 on port 1883.
2024-06-10 13:14:20: New client connected from 172.30.32.1:54785 as 2x6YiXG3Ww0qLGhyO506wd (p2, c1, k60, u'mqtt').
2024-06-10 13:14:20: Client 2x6YiXG3Ww0qLGhyO506wd disconnected.
2024-06-10 13:14:23: New connection from 172.30.32.1:43037 on port 1883.
2024-06-10 13:14:23: New client connected from 172.30.32.1:43037 as 2CrBSt8A1zwijdERA6CmYD (p2, c1, k60, u'mqtt').
and for Zigbee2MQTT
[2024-06-10 12:49:23] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:24] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:25] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:26] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:27] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:28] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:29] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:30] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:31] error: z2m:mqtt: Not connected to MQTT server!
[2024-06-10 12:49:35] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:36] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:37] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:38] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:39] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:41] error: z2m:mqtt: Not connected to MQTT server!
[2024-06-10 12:49:44] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:45] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:46] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:47] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:48] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:51] error: z2m:mqtt: Not connected to MQTT server!
[2024-06-10 12:49:53] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:54] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:55] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:56] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:49:57] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:01] error: z2m:mqtt: Not connected to MQTT server!
[2024-06-10 12:50:01] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:02] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:04] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:05] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:06] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:07] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:08] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:09] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:10] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:11] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:11] error: z2m:mqtt: Not connected to MQTT server!
[2024-06-10 12:50:15] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:16] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:17] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:18] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:19] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:21] error: z2m:mqtt: Not connected to MQTT server!
[2024-06-10 12:50:24] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:25] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:26] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:27] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:28] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:30] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:31] error: z2m:mqtt: Not connected to MQTT server!
[2024-06-10 12:50:31] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:32] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:33] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:34] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:39] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:40] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:41] error: z2m:mqtt: Not connected to MQTT server!
[2024-06-10 12:50:41] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:42] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:43] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:48] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:49] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:50] error: z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-10 12:50:51] error: z2m:mqtt: Not connected to MQTT server!
[2024-06-10 12:50:51] error: z2m:mqtt: Cannot send message: topic: 'zigbee2mqtt/bridge/state', payload: '{"state":"offline"}
[2024-06-10 12:50:51] info: z2m:mqtt: Disconnecting from MQTT server
[2024-06-10 12:50:51] info: z2m: Stopping zigbee-herdsman...
[2024-06-10 12:50:58] info: zh:controller: Wrote coordinator backup to '/config/zigbee2mqtt/coordinator_backup.json'
[2024-06-10 12:50:58] info: zh:zstack:znp: closing
[2024-06-10 12:50:58] info: zh:zstack:znp: Port closed
[2024-06-10 12:50:58] info: z2m: Stopped zigbee-herdsman
[2024-06-10 12:50:58] info: z2m: Stopped Zigbee2MQTT
[13:12:20] INFO: Preparing to start...
[13:12:21] INFO: Socat not enabled
[13:12:21] INFO: Starting Zigbee2MQTT...
[2024-06-10 13:12:23] info: z2m: Logging to console, file (filename: log.log)
[2024-06-10 13:12:23] info: z2m: Starting Zigbee2MQTT version 1.38.0 (commit #unknown)
[2024-06-10 13:12:23] info: z2m: Starting zigbee-herdsman (0.49.2)
[2024-06-10 13:12:23] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyUSB0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-06-10 13:12:23] info: zh:zstack:znp: Serialport opened
[2024-06-10 13:12:23] info: z2m: zigbee-herdsman started (resumed)
[2024-06-10 13:12:23] info: z2m: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"}'
[2024-06-10 13:12:23] info: z2m: Currently 0 devices are joined:
[2024-06-10 13:12:23] info: z2m: Zigbee: disabling joining new devices.
[2024-06-10 13:12:23] info: z2m:mqtt: Connecting to MQTT server at mqtt://core-mosquitto:1883
[2024-06-10 13:12:23] info: z2m:mqtt: Connected to MQTT server
[2024-06-10 13:12:23] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
[2024-06-10 13:12:23] info: z2m: Started frontend on port 8099
[2024-06-10 13:12:23] info: z2m: Zigbee2MQTT started!
[2024-06-10 13:12:28] info: z2m:mqtt: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x00124b002a2e5e50/connection_state/config', payload '{"device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2e5e50"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.38.0"},"device_class":"connectivity","entity_category":"diagnostic","name":"Connection state","object_id":"zigbee2mqtt_bridge_connection_state","origin":{"name":"Zigbee2MQTT","sw":"1.38.0","url":"https://www.zigbee2mqtt.io"},"payload_off":"offline","payload_on":"online","state_topic":"zigbee2mqtt/bridge/state","unique_id":"bridge_0x00124b002a2e5e50_connection_state_zigbee2mqtt","value_template":"{{ value_json.state }}"}'
[2024-06-10 13:12:28] info: z2m:mqtt: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x00124b002a2e5e50/restart_required/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2e5e50"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.38.0"},"device_class":"problem","enabled_by_default":false,"entity_category":"diagnostic","name":"Restart required","object_id":"zigbee2mqtt_bridge_restart_required","origin":{"name":"Zigbee2MQTT","sw":"1.38.0","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002a2e5e50_restart_required_zigbee2mqtt","value_template":"{{ value_json.restart_required }}"}'
[2024-06-10 13:12:28] info: z2m:mqtt: MQTT publish: topic 'homeassistant/button/1221051039810110150109113116116_0x00124b002a2e5e50/restart/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_topic":"zigbee2mqtt/bridge/request/restart","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2e5e50"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.38.0"},"device_class":"restart","name":"Restart","object_id":"zigbee2mqtt_bridge_restart","origin":{"name":"Zigbee2MQTT","sw":"1.38.0","url":"https://www.zigbee2mqtt.io"},"payload_press":"","unique_id":"bridge_0x00124b002a2e5e50_restart_zigbee2mqtt"}'
[2024-06-10 13:12:28] info: z2m:mqtt: MQTT publish: topic 'homeassistant/select/1221051039810110150109113116116_0x00124b002a2e5e50/log_level/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_template":"{\"options\": {\"advanced\": {\"log_level\": \"{{ value }}\" } } }","command_topic":"zigbee2mqtt/bridge/request/options","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2e5e50"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.38.0"},"entity_category":"config","name":"Log level","object_id":"zigbee2mqtt_bridge_log_level","options":["error","warning","info","debug"],"origin":{"name":"Zigbee2MQTT","sw":"1.38.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002a2e5e50_log_level_zigbee2mqtt","value_template":"{{ value_json.log_level | lower }}"}'
[2024-06-10 13:12:28] info: z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00124b002a2e5e50/version/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2e5e50"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.38.0"},"entity_category":"diagnostic","icon":"mdi:zigbee","name":"Version","object_id":"zigbee2mqtt_bridge_version","origin":{"name":"Zigbee2MQTT","sw":"1.38.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002a2e5e50_version_zigbee2mqtt","value_template":"{{ value_json.version }}"}'
[2024-06-10 13:12:28] info: z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00124b002a2e5e50/coordinator_version/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2e5e50"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.38.0"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:chip","name":"Coordinator version","object_id":"zigbee2mqtt_bridge_coordinator_version","origin":{"name":"Zigbee2MQTT","sw":"1.38.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002a2e5e50_coordinator_version_zigbee2mqtt","value_template":"{{ value_json.coordinator.meta.revision }}"}'
[2024-06-10 13:12:28] info: undefined: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00124b002a2e5e50/network_map/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2e5e50"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.38.0"},"enabled_by_default":false,"entity_category":"diagnostic","json_attributes_template":"{{ value_json.data.value | tojson }}","json_attributes_topic":"zigbee2mqtt/bridge/response/networkmap","name":"Network map","object_id":"zigbee2mqtt_bridge_network_map","origin":{"name":"Zigbee2MQTT","sw":"1.38.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/response/networkmap","unique_id":"bridge_0x00124b002a2e5e50_network_map_zigbee2mqtt","value_template":"{{ now().strftime('%Y-%m-%d %H:%M:%S') }}"}'
[2024-06-10 13:12:28] info: z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00124b002a2e5e50/permit_join_timeout/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2e5e50"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.38.0"},"device_class":"duration","entity_category":"diagnostic","name":"Permit join timeout","object_id":"zigbee2mqtt_bridge_permit_join_timeout","origin":{"name":"Zigbee2MQTT","sw":"1.38.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002a2e5e50_permit_join_timeout_zigbee2mqtt","unit_of_measurement":"s","value_template":"{{ iif(value_json.permit_join_timeout is defined, value_json.permit_join_timeout, None) }}"}'
[2024-06-10 13:12:28] info: z2m:mqtt: MQTT publish: topic 'homeassistant/switch/1221051039810110150109113116116_0x00124b002a2e5e50/permit_join/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_topic":"zigbee2mqtt/bridge/request/permit_join","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2e5e50"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.38.0"},"icon":"mdi:human-greeting-proximity","name":"Permit join","object_id":"zigbee2mqtt_bridge_permit_join","origin":{"name":"Zigbee2MQTT","sw":"1.38.0","url":"https://www.zigbee2mqtt.io"},"payload_off":"false","payload_on":"true","state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002a2e5e50_permit_join_zigbee2mqtt","value_template":"{{ value_json.permit_join | lower }}"}'
It makes no sense to me and it’s driving me crazy
