I configured MQTT exactly how Ben shows in his video on Youtube (BRUH Automation). It worked when I configured it. After reboot, I found that it does not work. When I try to run mosquitto_sub command, I have the following:
pi@Home-Assistant:~ $ mosquitto_sub -d -u username -P password -t "dev/test"
Error: Connection refused
After long testing, I found that Mosquitto service is not running:
pi@Home-Assistant:~ $ sudo systemctl status mosquitto.service
● mosquitto.service - Mosquitto MQTT Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; disabled)
Active: inactive (dead)
Docs: man:mosquitto(8)
https://mosquitto.org/
I found that if I want it to work, I have to manually run the following commands:
sudo systemctl stop home-assistant.service
sudo systemctl start mosquitto
sudo systemctl start home-assistant.service
After I run above three commands, everything works.
What is wrong? How can I fix it?
Thank you.
