knebb
October 26, 2021, 10:38am
1
I have some sensors which are updated through MQTT. Some of them have boolean values as follows:
"status": {
"daemon": true,
"manual": false,
"nacht": false,
"test": false,
"heizung": true
To get this values into Grafana I would like to map them as “0” and “1” (from “false” and “true”).
I tried with the template but did not succeed due to some syntax error I do not know how to resolve:
- platform: mqtt
state_topic: hzg/status
force_update: true
value_template: '{{ value_json.status.daemon | regex_replace(find='true', replace='1') | regex_replace(find='false', replace='0')}}'
The editor shows me:
can not read an implicit mapping pair; a colon is missed at line 58, column 135:
... e(find='false', replace='0') }}'
Anyone having an idea how to convert this properly?
Thanks!
/KNEBB
Something like:
"{% if value_json.staus.daemon == 'true' %} 1 {% else %} 0 {% endif %}"
should work.
knebb
October 26, 2021, 10:59am
3
Ok, now I have the issue of not being sure whre and how to insert your code.
value_template: '{{% if value_json.relais.r_wp == 'true' %} 1 {% else %} 0 {% endif %}}'
Does not work (getting sysntax errors).
Sorry, syntax of these entries is not self-explaining…
Thanks!
/KNEBB
If you are using single quotes within the template you must use double quotes at either end of the template
value_template: "{{% if value_json.relais.r_wp == 'true' %} 1 {% else %} 0 {% endif %}}"
knebb
October 26, 2021, 11:20am
5
Sorry to bother you… but using the suggested sniplet results in:
invalid config for [sensor.mqtt]: invalid template (TemplateSyntaxError: unexpected '%') for dictionary value @ data['value_template']. Got "{{% if value_json.relais.r_wp == 'true' %} 1 {% else %} 0 {% endif %}}". (See ?, line ?).
My config:
- platform: mqtt
force_update: true
I tried either the other way with single/ double quotes. No change.
You have double curly brackets at either end of the template.
You only want single curly brackets.
You want
value_template: "{% if value_json.relais.r_wp == 'true' %} 1 {% else %} 0 {% endif %}"
knebb
October 26, 2021, 11:30am
7
jivesinger:
You want
I really, really want to understand syntax here. But it looks like not even you experienced (and very helpful) lads are really sure how it work.
However, your last suggestion still does not work:
Invalid config for [sensor.mqtt]: invalid template (TemplateSyntaxError: unexpected char '‘' at 33) for dictionary value @ data['value_template']. Got '“{% if value_json.relais.r_wp == ‘true’ %} 1 {% else %} 0 {% endif %}”'. (See ?, line ?).
- platform: mqtt
force_update: true
value_template: “{% if value_json.relais.r_wp == ‘true’ %} 1 {% else %} 0 {% endif %}”
/KNEBB
Dujith
(Charles Evers)
October 26, 2021, 11:41am
8
value_template: >
1
{% else %}
0
{% endif %}
As shown in Template - Home Assistant
Edit:
@knebb In HA you have the Developer Tools and there is a template debug there.
Just insert whatever template you want to test and see at once if it gives a value or error.
knebb
October 26, 2021, 11:42am
9
Nevermind.
This time it was a simple cut&paste error.
The ’ where replaced by backticks.
At least I do not have syntax errors right now. I will monitor to see if the value gets properly populated to Grafana.
Thanks so far!
/KNEBB
Last try
Remove the single quotes around true
in your template.
value_template: “{% if value_json.relais.r_wp == true %} 1 {% else %} 0 {% endif %}”
(Taras)
October 26, 2021, 11:57am
11
To convert boolean true
/false
to integer 1
/0
simply use the abs
filter (absolute).
- platform: mqtt
force_update: true
value_template: '{{ value_json.status.daemon | abs }}'
This won’t work if the value is string true
/false
knebb
October 26, 2021, 12:18pm
12
Hi @123
No, they are indeed boolean, not strings:
"relais": {
"r_wp": true,
"r_ehzg": false,
"r_pump": true,
"r_lhzr": 95
When I used the suggested " then the result is a “0” as string- which is not good for Grafana.
So I used the single one outside and the double around true
Now it works. I do not know what the abs
function will do but I am happy how it is currently.
value_template: '{% if value_json.relais.r_wp == "true" %} 1 {% else %} 0 {% endif %}'
Thanks for all input!
/KNEBB
knebb
October 26, 2021, 12:27pm
13
Last update:
For some reason the %if% %else% version did not work and always produced the value 0.
I used the second solution with abs
and this now finally works fine!
/KNEBB
123
(Taras)
October 26, 2021, 12:33pm
14
If the received value is not a string, then it failed to work because it was being compared to a string.
The double-quotes
make this a string
Either remove the double-quotes or just use abs
{{ value_json.relais.r_wp | abs }}
knebb
October 26, 2021, 12:37pm
15
Oh guys, HoAss is really complicated…
I guess I am understanding finally. At least partially.
So both of the following should work without issues:
value_template: '{% if value_json.relais.r_wp == true %} 1 {% else %} 0 {% endif %}'
Finally…
123
(Taras)
October 26, 2021, 12:41pm
16
Glad to hear it. However, it also means the post you marked as the Solution is now no longer the correct solution because it compares the value to a string true
Please consider marking my post above with the Solution tag so other users are informed of the correct way to solve this issue.
