I have an ESP8266 with the milight control. When i activate a light, the lamp goes on, the switch in hass returns to off immediately while the lamp stays on. thus i cannot control the color/brightness or turn off the light.
my config for the lights:
light:
name: “Milight Lamp #1”
command_topic: milight/0x02FF/rgb_cct/1
state_topic: milight/states/0x02FF/rgb_cct/1
<<: &MILIGHT_PARAMS
platform: mqtt_json
color_temp: true
rgb: true
brightness: true -
name: “Milight Lamp #2”
command_topic: milight/0x02FF/rgb_cct/2
state_topic: milight/states/0x02FF/rgb_cct/2
<<: *MILIGHT_PARAMS -
name: “Milight Lamp #3”
command_topic: milight/0x02FF/rgb_cct/3
state_topic: milight/states/0x02FF/rgb_cct/3
<<: *MILIGHT_PARAMS
Mqtt topic pattern:
milight/:device_id/:device_type/:group_id
mqtt update topic pattern:
milight/update/:device_id/:device_type/:group_id
mqtt state topic pattern:
milight/states/:device_id/:device_type/:group_id
I think the state topic is not updated since i see no info in this topic ever. How can i fix this?
