Cloolalang
(Cloolalang)
February 3, 2021, 2:11pm
1
Extracting a value in JSON object, but only if another value is true
Incoming data: (its from a LoraWan Server)
{"applicationID":"6","applicationName":"Lab","devEUI":"0000000000000002","deviceName":"dev-0000000000000002","timestamp":1612360964,"fCnt":177,"fPort":1,"data":"0C800C4E","data_encode":"hexstring","adr":false,"rxInfo":[{"gatewayID":"ac1f09fffe00aba2","loRaSNR":6.3,"rssi":-105,"location":{"latitude":-33.xxxxx,"longitude":18.xxxxx,"altitude":15}}],"txInfo":{"frequency":867700000,"dr":5}}
Wanted value:
“data”:“0C800C4E”
but only if:
fport == 1 “fPort”:1,
Do I need to use a script of can this be done within jinja sensor template?
Any ideas would be very much appreciated!
P
tom_l
February 3, 2021, 3:35pm
2
You can do it with jinja, but you have not said what you want if data != 1.
If you want it to retain the previous value and the template sensor entity_id is sensor.test
value_template: "{{ value_jason.data if value_json.fport == 1 else states('sensor.test') }}"
Cloolalang
(Cloolalang)
February 3, 2021, 4:02pm
3
Hi Tom_I,
Thanks very much for looking at this and giving me a pointer…
Im basically tying to setup MQTT sensors for each Fport.
I will be receiving JSON objects every 10 mins with fports being set between 1 and 10 and I would like a sensor for each one as each fport will represent a different data type.
EG:
Fport Data:
1 Temperature
2 Light level
I tried this:
platform: mqtt
state_topic: "RAK-application/6/device/0000000000000003/rx"
But Im not seeing any data on test1
P
tom_l
February 3, 2021, 4:10pm
4
This:
Cloolalang:
Must match this:
So:
platform: mqtt
value_template: "{{ value_jason.data if value_json.fport == 1 else states('sensor.test1') }}"
Cloolalang
(Cloolalang)
February 3, 2021, 4:19pm
5
Thanks.
I tried in the Developer Tools:
{% set value_json={“applicationID”:“6”,“applicationName”:“Patricks Lab”,“devEUI”:“0000000000000002”,“deviceName”:“dev-0000000000000002”,“timestamp”:1612368549,“fCnt”:423,“fPort”:1,“data”:“10CC0C62”,“data_encode”:“hexstring”,“adr”:false,“rxInfo”:[{“gatewayID”:“ac1f09fffe00aba2”,“loRaSNR”:5.8,“rssi”:-103,“location”:{“latitude”:-33.990200,“longitude”:18.473170,“altitude”:15}}],“txInfo”:{“frequency”:867300000,“dr”:5}}
{{ value_jason.data if value_json.fPort == 1 else states(‘sensor.test’) }}
RESULT:
UndefinedError: ‘value_jason’ is undefined
Any Ideas?
tom_l
February 3, 2021, 4:39pm
6
Ugh. Stupid autocorrect (or me).
json not jason
Try this:
platform: mqtt
value_template: "{{ value_json.data if value_json.fport == 1 else states('sensor.test1') }}"
Cloolalang
(Cloolalang)
February 3, 2021, 5:48pm
7
I owe you beer dear friend.
Thanks very much!
Patrick
