Hi.
I’ve just installed an MQTT Mosquitto broker on the same Raspberry PI that hosts HA.
I’ve defined an external ESP32 configured as an MQTT publisher that sends a simple test dataset every ten seconds to the Mosquitto broker.
Finally I’ve added this code to the configuration.yaml :
# Example configuration.yaml entry
mqtt:
- name: "ESP32-pin 25-Volts"
state_topic: "studio/test/pin25"
unit_of_measurement: "Volts"
payload_available: "online"
payload_not_available: "offline"
force_update: true
The issue is that even if I shutdwon the external ESP32 board on the HA’s dashboard I see the last value sended while I’d like to show that the board is offline.
Any idea?
