Hi.
Having some issues with MQTT light and color temperature.
I have 1x dimmable light working with this config:
#1 - Temperature light
- schema: template
name: "Test Temperature Light"
state_topic: "hdl/sc/2.11/1"
command_topic: "hdl/sc/2.11/1/set"
command_on_template: >
{"state": "on"
{%- if brightness is defined -%}
, "level": {{ brightness }}
{%- else -%}
, "level": 255
{%- endif -%}
command_off_template: '{"state": "off", "level": 0}'
state_template: "{{ 'on' if value_json.level | int > 0 else 'off' }}"
brightness_template: "{{ value_json.level }}"
Wanted to add support for color temperature and added “color_temp_state_topic” and “color_temp_command_topic” according to MQTT Light Documentation
- schema: template
color_temp_state_topic: "hdl/ct/2.11/1"
color_temp_command_topic: "hdl/ct/2.11/1/set"
{"state": "on"
{%- else -%}
, "level": 255
{%- endif -%}
This creates an error when checking configuration under development tools:
Invalid config for [mqtt]: [color_temp_state_topic] is an invalid option for [mqtt]. Check: mqtt->mqtt->light->0->color_temp_state_topic. (See /config/configuration.yaml, line 6).
Hope somebody can explain what i am doing wrong?
Version:
Home Assistant 2022.9.4
Supervisor 2022.10.0
Operating System 9.0
Frontend 20220907.2 - latest
