Hi there!
I want to combine my switch and smart bulb so: The on/off command is send to the switch, and the brightness is send to the bulb.
Whay i’ve got right now:
- platform: mqtt
command_topic: "zigbee2mqtt/Eetkamer Schakelaar/l1/set"
state_topic: "zigbee2mqtt/Eetkamer Schakelaar"
state_value_template: "{{ value_json.state_l1 }}"
brightness_command_topic: "zigbee2mqtt/Eetkamer/set"
The on/off works great, but brightness isn’t working. This because home assistant will send zigbee2mqtt/Eetkamer/set
with payload the brightness value. But it has to be {"brightness": VALUE}
does anyone has any idea how i can set the brightness command payload?
Update:
I’ve made a PR to support this: Mqtt light cmd template by rubenverhoef · Pull Request #63361 · home-assistant/core · GitHub
