I tried to add another MQTT Light to my homeassistant setup.
The problem is, it does not show up in the lovelace ui and I have no idea why.
my configuration.yaml contains:
light:
- platform: mqtt
state_topic: "jonas/light/status"
command_topic: "jonas/light/switch"
brightness_state_topic: 'jonas/light/brightness/status'
brightness_command_topic: 'jonas/light/brightness/set'
brightness_scale: 100
rgb_state_topic: 'jonas/light/rgb/status'
rgb_command_topic: 'jonas/light/rgb/set'
qos: 0
payload_on: "ON"
payload_off: "OFF"
optimistic: false
- platform: mqtt
state_topic: "jonas/pclight/status"
command_topic: "jonas/pclight/switch"
brightness_state_topic: 'jonas/pclight/brightness/status'
brightness_command_topic: 'jonas/pclight/brightness/set'
brightness_scale: 255
rgb_state_topic: 'jonas/pclight/rgb/status'
rgb_command_topic: 'jonas/pclight/rgb/set'
# effect_state_topic: 'jonas/pclight/effect/status'
# effect_command_topic: 'jonas/pclight/effect/set'
# effect_list:
# - Rainbow
# - Flicker Blue
qos: 0
payload_on: "ON"
payload_off: "OFF"
optimistic: false
The first entry “Jonas Lampe” was already there and works well. I added the second entry
“Jonas PCLight” and then added this to my ui-lovelace.yaml:
- title: Jonas
cards:
- type: light
entity: light.jonas_lampe
- type: light
entity: light.jonas_pclight
The new Tab in the lovelace UI appears as expected, but there is only one card that shows the entity: light.jonas_lampe, the new one, does not appear.
My log does not show a hint what the problem may be:
2019-11-12 22:00:29 ERROR (MainThread) [homeassistant.setup] Setup failed for introduction: Integration not found.
2019-11-12 22:00:31 WARNING (MainThread) [homeassistant.bootstrap] Python 3.6 support is deprecated and will be removed in the first release after December 15, 2019. Please upgrade Python to 3.7.0 or higher.
2019-11-12 22:00:32 WARNING (MainThread) [homeassistant.components.script] Script script.publish_mqtt_message already running.
Perhaps, someone has an idea, what the problem is?
