Mqtt light going offline without reason
Today, I noticed one of my AC powered switches disappear (BTW the one this thread has started with)
look at this:
History shows it turned unavailable yesterdayand remains till now.
But MQTT debug log shows events from today (even a few mins ago)
Since yesterday I have debug enabled for core too. The image above shows grep for entrance word. So no such line in core.debug
Any ideas WTF is going on? It’s not only about I lost entity. But it is not able to recover itself with data still comming from MQTT.
How can I debug this issue more? I suspect even with this evidence, there is no chance to get help from devs.
found reason of report above. But rootcause is still unknow:
You may see, online topic turned false.
Curious why… I suspect only the device writes there. but why the device would report offline while it’s online all the time?
Bug in Shelly
It’s about Shelly Motion (bit different HW). But it might originate from from the same logic implemented in the code base. So yes, it could be.
I already asked for that behavior on Shelly FB. Will see.
I have to check logs for battery powered devices (a few posts above). Going offline is something normal for them. It might be different case from Shelly2.5
Thank you for the feedback
Check your discovery configuration and remove the online/offline and see if the issue goes away
I’m not using discovery. Manually configured entities instead.
Yeah… idea of removing availability check came across my mind. Thanks
Manual configuration uses the same code as discovery. The yaml is just passed to the objects instead of the discovery info. So it’s a 1 to 1 comp in that regards
Yes. I assume that. Thank you.
So, looks like I’m facing two different issues. Still waiting on asnwer from Shelly about AC powered device.
But I just encountered again issue with battery powered devices. All my battery Shelly H&T turned unavailable recently.
Main differences between them and mentioned above AC powerd devices are:
  • those devices have no availability topic set
  • those devices has expiration timeout to 24h
What happened yesterday is, I restarted HA at 12:51, then was reloading manually configured mqtt entities multiple times during a day.
Here is what found in logs:
cat ./home-assistant.log | grep -E "temp-kitchen|kitchen_temperature" | grep -v table
2021-11-20 16:30:16 DEBUG (MainThread) [homeassistant.components.mqtt] Subscribing to shellies/temp-kitchen/sensor/temperature, mid: 5779
2021-11-20 16:30:16 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-kitchen/sensor/temperature (retained): b'22.20'
2021-11-20 16:30:16 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.kitchen_temperature, old_state=None, new_state=<state sensor.kitchen_temperature=22.20; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-20T16:30:16.100838+01:00>>
2021-11-20 16:30:16 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.kitchen_temperature, old_state=<state sensor.kitchen_temperature=22.20; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-20T16:30:16.100838+01:00>, new_state=<state sensor.kitchen_temperature=22.20; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-20T16:30:16.134957+01:00>>
2021-11-20 16:30:16 DEBUG (MainThread) [homeassistant.components.mqtt] Subscribing to shellies/temp-kitchen/sensor/humidity, mid: 5780
2021-11-20 16:30:16 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-kitchen/sensor/humidity (retained): b'54.0'
2021-11-21 02:28:08 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-kitchen/sensor/temperature: b'22.20'
2021-11-21 02:28:08 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.kitchen_temperature, old_state=<state sensor.kitchen_temperature=22.20; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-20T16:30:16.134957+01:00>, new_state=<state sensor.kitchen_temperature=22.20; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T02:28:08.155853+01:00>>
2021-11-21 02:28:08 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-kitchen/sensor/humidity: b'52.5'
2021-11-21 02:28:08 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-kitchen/sensor/battery: b'100'
2021-11-21 11:04:13 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.kitchen_temperature, old_state=<state sensor.kitchen_temperature=22.20; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T02:28:08.155853+01:00>, new_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T11:04:13.148924+01:00>>
2021-11-21 12:51:16 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.kitchen_temperature, old_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T11:04:13.148924+01:00>, new_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T12:51:16.969906+01:00>>
2021-11-21 12:54:34 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.kitchen_temperature, old_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T12:51:16.969906+01:00>, new_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T12:54:34.166672+01:00>>
2021-11-21 14:07:50 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.kitchen_temperature, old_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T12:54:34.166672+01:00>, new_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:07:50.729207+01:00>>
2021-11-21 14:19:19 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-kitchen/sensor/temperature: b'22.45'
2021-11-21 14:19:19 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.kitchen_temperature, old_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:07:50.729207+01:00>, new_state=<state sensor.kitchen_temperature=22.45; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:19:19.935248+01:00>>
2021-11-21 14:19:19 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-kitchen/sensor/humidity: b'54.5'
2021-11-21 14:19:19 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-kitchen/sensor/battery: b'100'
2021-11-21 14:21:20 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.kitchen_temperature, old_state=<state sensor.kitchen_temperature=22.45; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:19:19.935248+01:00>, new_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:21:20.422972+01:00>>
2021-11-21 14:25:08 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-kitchen/sensor/temperature: b'22.83'
2021-11-21 14:25:08 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.kitchen_temperature, old_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:21:20.422972+01:00>, new_state=<state sensor.kitchen_temperature=22.83; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:25:08.503409+01:00>>
2021-11-21 14:25:08 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-kitchen/sensor/humidity: b'54.0'
2021-11-21 14:25:08 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-kitchen/sensor/battery: b'100'
2021-11-21 14:27:31 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.kitchen_temperature, old_state=<state sensor.kitchen_temperature=22.83; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:25:08.503409+01:00>, new_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:27:31.002663+01:00>>
2021-11-21 14:33:31 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.kitchen_temperature, old_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:27:31.002663+01:00>, new_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:33:31.424737+01:00>>
2021-11-21 14:36:52 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.kitchen_temperature, old_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:33:31.424737+01:00>, new_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:36:52.829243+01:00>>
2021-11-21 14:39:58 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.kitchen_temperature, old_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:36:52.829243+01:00>, new_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:39:58.600221+01:00>>
2021-11-21 14:41:59 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.kitchen_temperature, old_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:39:58.600221+01:00>, new_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:41:59.945812+01:00>>
2021-11-21 14:49:01 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.kitchen_temperature, old_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:41:59.945812+01:00>, new_state=<state sensor.kitchen_temperature=unavailable; unit_of_measurement=°C, friendly_name=Kitchen Temperature, device_class=temperature @ 2021-11-21T14:49:01.481926+01:00>>
In short,
at 2:28 most recent temperature value has been received from mqtt and set in entity
at 11:04 for some reason this sensor has been refreshed with the same values
at 12:51 temperature sensor went unavailable,
at 14:19 temperature is set to valid value because is refreshed from mqtt
at 14:21 it turns unavailable again without reason
at 14:25 temperature is set to valid value because is refreshed from mqtt
at 14:27 it turns unavailable again without reason
Reason of next sensor updates are not known for me but are executed roughly every 3 minutes not changing the state.
Because I make a grep for mqtt topic but for temperature sensor name, there are no log lines shown for humidity and battery sensor of this device. But both are unavailable too.
Here is similar log for other sensor. The behavior and timing are the same:
2021-11-20 16:30:15 DEBUG (MainThread) [homeassistant.components.mqtt] Subscribing to shellies/temp-pcroom/sensor/humidity, mid: 5774
2021-11-20 16:30:15 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pcroom_temperature, old_state=<state sensor.pcroom_temperature=25.50; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-20T16:30:15.919348+01:00>, new_state=<state sensor.pcroom_temperature=25.50; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-20T16:30:15.924397+01:00>>
2021-11-20 16:30:15 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-pcroom/sensor/humidity (retained): b'50.0'
2021-11-20 18:53:15 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-pcroom/sensor/temperature: b'24.50'
2021-11-20 18:53:15 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pcroom_temperature, old_state=<state sensor.pcroom_temperature=25.50; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-20T16:30:15.924397+01:00>, new_state=<state sensor.pcroom_temperature=24.50; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-20T18:53:15.162819+01:00>>
2021-11-20 18:53:15 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-pcroom/sensor/humidity: b'50.0'
2021-11-20 18:53:15 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-pcroom/sensor/battery: b'100'
2021-11-21 03:57:42 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-pcroom/sensor/temperature: b'23.50'
2021-11-21 03:57:42 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pcroom_temperature, old_state=<state sensor.pcroom_temperature=24.50; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-20T18:53:15.162819+01:00>, new_state=<state sensor.pcroom_temperature=23.50; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T03:57:42.206813+01:00>>
2021-11-21 03:57:42 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-pcroom/sensor/humidity: b'49.5'
2021-11-21 03:57:42 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-pcroom/sensor/battery: b'100'
2021-11-21 11:20:29 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-pcroom/sensor/temperature: b'24.50'
2021-11-21 11:20:29 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pcroom_temperature, old_state=<state sensor.pcroom_temperature=23.50; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T03:57:42.206813+01:00>, new_state=<state sensor.pcroom_temperature=24.50; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T11:20:29.190627+01:00>>
2021-11-21 11:20:29 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-pcroom/sensor/humidity: b'50.0'
2021-11-21 11:20:29 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on shellies/temp-pcroom/sensor/battery: b'100'
2021-11-21 11:41:07 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pcroom_temperature, old_state=<state sensor.pcroom_temperature=24.50; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T11:20:29.190627+01:00>, new_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T11:41:07.293522+01:00>>
2021-11-21 12:51:16 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pcroom_temperature, old_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T11:41:07.293522+01:00>, new_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T12:51:16.779165+01:00>>
2021-11-21 13:47:07 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pcroom_temperature, old_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T12:51:16.779165+01:00>, new_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T13:47:07.439301+01:00>>
2021-11-21 14:07:50 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pcroom_temperature, old_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T13:47:07.439301+01:00>, new_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T14:07:50.398601+01:00>>
2021-11-21 14:21:20 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pcroom_temperature, old_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T14:07:50.398601+01:00>, new_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T14:21:20.243528+01:00>>
2021-11-21 14:27:30 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pcroom_temperature, old_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T14:21:20.243528+01:00>, new_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T14:27:30.825043+01:00>>
2021-11-21 14:33:31 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pcroom_temperature, old_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T14:27:30.825043+01:00>, new_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T14:33:31.245656+01:00>>
2021-11-21 14:35:34 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pcroom_temperature, old_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T14:33:31.245656+01:00>, new_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T14:35:34.314269+01:00>>
2021-11-21 14:39:58 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pcroom_temperature, old_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T14:35:34.314269+01:00>, new_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T14:39:58.214383+01:00>>
2021-11-21 14:41:59 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pcroom_temperature, old_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T14:39:58.214383+01:00>, new_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T14:41:59.662461+01:00>>
2021-11-21 14:49:01 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pcroom_temperature, old_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T14:41:59.662461+01:00>, new_state=<state sensor.pcroom_temperature=unavailable; unit_of_measurement=°C, friendly_name=PCroom Temperature, device_class=temperature @ 2021-11-21T14:49:01.204123+01:00>>
And here are configuration of the sensor:
# KITCHEN SENSORS
# - temperature
# - humidity
# - battery
- platform: mqtt
  name: "Kitchen Temperature"
  state_topic: "shellies/temp-kitchen/sensor/temperature"
  json_attributes_topic: "shellies/temp-kitchen/sensor/temperature"
  unit_of_measurement: "°C"
  force_update: true
  device_class: temperature
  expire_after: 86400
- platform: mqtt
  name: "Kitchen Humidity"
  state_topic: "shellies/temp-kitchen/sensor/humidity"
  json_attributes_topic: "shellies/temp-kitchen/sensor/humidity"
  unit_of_measurement: "%"
  payload_available: "true"
  payload_not_available: "false"
  force_update: true
  device_class: humidity
  expire_after: 86400
- platform: mqtt
  state_topic: "shellies/temp-kitchen/sensor/battery"
  force_update: true
  device_class: battery
  expire_after: 86400
  sensors:
    kitchen_temp_battery:
      friendly_name: "Kitchen Sensor Battery"
      value_template: "{{ states('sensor.kitchen_bttry') }}"
(just noticed payload_available/payload_not_available set for 2 of those sensors. but it should make no difference since topic is not defined. Also temperature sensor has no those settings but fails too)
Just thinking if it has something to do with HA restart (see the same time, but one day later, one day = 24h) and possibly with subsequent mqtt entities reloading.
I have other battery powered shelly sensors (DW) but those have no expiration set. And they remain available.
Do you think it’s enough to raise issue on GitHub?
I reported expiration issue to github. Due to no any response, I decided to remove expiration from entities. Tbh not having this feature is less problematic than loosing sensors every few days.
Anyway what is more important I found that after removing expiration lines from entity configs and reloading manually configured mqtt entities, next day I lost those entities again.
It confirms that something is really screwed around this.
Then I restarted HA and since this time no more issues.
Maybe worth to say again that I’m talking about battery powered devices (see config in prev posts) so there is no way they turn unavailable. Also in order to make sure there are no invalid data causing this issue I created test sensors based on the same mqtt topics with use of NR. So I’m pretty sure there is an issue in HA core.
BTW, can you help somehow with pushing this git issue forward? 3 weeks without any reaction. Not sure if it’s expected in case of such a crucial component like mqtt.
Issues like this could take months to identify before a fix can be applied. The fact that you can’t identify it yourself and you have the issue shows that anyone else without the issue is going to have even more difficulty identifying the problem. Best advice I can give is to be patient and keep the issue alive by responding in it.
Yeah, I’d like to respond and help but nobody asking questions. Im afraid that after month or two bots will start closing this issue due to no development activity (which is extremely discouraging for reporters and imo doesn’t help anything, but this is subject for another discussion)
I think I narrowed the issue down to the feature of manual reloading entities. There should be no big problem to find what has been forgotten (fixing might be more complex depending on various things, though)
if you respond, the issue doesn’t get closed
the bot does not distinguish between members and non-members. It only cares about active conversations
here’s the code: as an FYI reloading reinits the entity. Both onboarding and reloading follow the same code. It could be related but I doubt it seeing as the config will be the same.
init
updating the state
the availability
To me, if this were a bug it would be in the availability, and I would start looking at the fget because the availability is based on the expiration and if it exists in that database. The reload may clear that accidentally or something
Hello. Seems the bug has been identified and the fix prepared.
But I’m not sure what next. Seems it didn’t get into any release yet. Label says it should be released withing 2022.2.x releases. (8 patches has been released since then)
Unfortunately more than 2 weeks there is no movement (while issue has been closed by a bot). I cannot find any information in github confirming it has been merged to official release branch.
Can you help describing current situation?
it’s merged, so it’s probably going into 2022.3
Yeah I saw merged to dev. But since emontnemery labeled it as 2022.2 milestone I though It will get to Feb.
Anyway thank you for instant answer.
I don’t know the process to 100%, but I’m fairly sure frenck just chooses the safest PR fixes for the xxxx.x.1+ fixes and all the volatile stuff goes into xxxx.x.0 & dev builds.
Could you please assist me finding confirmation if this fix either landed in 2022.3 or not?
It seems it’s not mentioned in changelog as well as I cannot see any references in GitHub
