Hello, I’m trying to create an Mqtt Light entity. I’m doing the following: In my config.yaml:
mqtt:
- light:
unique_id: "Buero"
command_topic: "modbus/LightButton/set/Buero"
state_topic: "modbus/LightActualLevel/state/Buero"
payload_on: "100.0"
payload_off: "0.0"
on_command_type: 'first'
optimistic: false
state_value_template: "{{ 'on' if value == '100.0' else 'off' }}"
This creates an entity for me which I can also see in the developer tools under States.
Here is my first question, why state Unknown?
I can also control the light with the switch using a small script:
alias: mqttButtonBuero
sequence:
- service: mqtt.publish
metadata: {}
qos: 0
retain: false
topic: modbus/LightButton/set/Buero
payload: "True"
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 200
metadata: {}
qos: 0
retain: false
payload: "False"
mode: single
which is called in the custom:button-card:
type: custom:button-card
icon: |
if (states['light.buero'].value == 'on')
return 'mdi:lightbulb-on-outline';
else return 'mdi:lightbulb-outline';
tap_action:
action: call-service
service: script.mqttbuttonbuero
styles:
card:
- background-color: |
if (states['light.buero'].value == 'off')
return 'red';
When the button is pressed, the state of the topic changes from 0.0 to 100.0:
And so I thought the custom:button-card would change color.
But it doesn’t, and I can’t figure out why.
Maybe someone can help me.
Best regards,
Patrick
tom_l
June 11, 2024, 12:06am
2
Your commands to control the Light are “True” and “False”. These are the payloads you need to define so that is what the integration will send on the command topic.
Then you need to match the returned state mqtt messages that are received on the state topic to these payloads, see:
https://www.home-assistant.io/integrations/light.mqtt/#state_value_template
Try this:
mqtt:
- light:
unique_id: "Buero"
payload_on: "True"
payload_off: "False"
optimistic: false
state_value_template: "{{ 'True' if value == '100.0' else 'False' }}"
Thanks,thats it, now the State changes from off to on.
But how can i change the Icon or background?
icon: |
tap_action:
styles:
card:
return 'red';
doesn’t work?
marsmaennchen:
light.buero
This should work for you
entity: light.buero
icon: |
[[[ return entity.state === 'on' ? 'mdi:lightbulb-on-outline' : 'mdi:lightbulb-outline';
tap_action:
styles:
card:
[[[ return entity.state === 'on' ? 'grey' : 'red';
Thank you so much!
The solution is:
mqtt:
- light:
unique_id: "Buero"
payload_on: "True"
optimistic: false
And my Card:
entity: light.buero
icon: >
tap_action:
styles:
card:
