MQTT light invalid brightness value received
I control multiple Shelly lights via MQTT. Controlling the lights (on/off & brightness) works without any problem. Getting the state (on/off) also works but getting the current brightness fails. See the warning log warning below:
Logger: homeassistant.components.mqtt.light.schema_template
Source: components/mqtt/light/schema_template.py:218
Integration: MQTT
First occurred: 12:44:25 (3023 occurrences)
Last logged: 21:06:13
Invalid brightness value received
I use the following confguration:
light:
  - platform: mqtt
    unique_id: 'shelly-vintage-xxxxxx'
    device:
      connections: [["mac", "xx:xx:xx:xx:xx:xx"]]
      manufacturer: 'Shelly'
      model: 'Shely Vintage ST64'
    schema: template
    command_topic: 'shellies/ShellyVintage-xxxxxx/light/0/set'
    state_topic: 'shellies/ShellyVintage-xxxxxx/light/0/status'
    state_template: '{% if value_json.ison %} on {% else %} off {% endif %}'
    command_on_template: '{ {% if brightness is defined %}"brightness": {{ brightness / 2.55 }}, {%- endif -%}"turn": "on"}'
    command_off_template: '{"turn": "off"}'
    brightness_template: '{{ value_json.brightness | float * 2.55 }}'
The payload of on the topic shellies/ShellyVintage-xxxxxx/light/0/status looks like:
{"ison":true,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"brightness":100}
The brightness range is 0-100. That’s the reason for the * 2.55 (and / 2.55 in the command_on_template)
I also tried only value_json.brightness (without ```* 2.55) but that also didn’t work (same warning log).
My current Home Assistant version is 0.117.6 and HassOS 4.15 running on a Raspberry Pi 1B+.
I’m wondering what I’m doing wrong.
It’s probably expecting integers. Try this:
    command_on_template: '{ {% if brightness is defined %}"brightness": {{ (brightness / 2.55)|int }}, {%- endif -%}"turn": "on"}'
    brightness_template: '{{ (value_json.brightness | float * 2.55)int }}'
Thanks for your quick response.
Found out that Home Assistant indeed expects an int for the brightness. I now used the following configuration which works (a little bit different than your suggestion):
brightness_template: ‘{{ (value_json.brightness | float * 2.55) | int }}’
Thanks again!
Ok I got the reason right but not the solution. The format I posted is definitely not correct. Sorry. Probably should not post at 2am.
No problem at all. You helped me out so thank you for your post.
I posted my final solution for others that may have less programming experience and aren’t be able to figure out themselves.
