I have an issue with my light state is toggling back to off after using the light switch. But sensor that pulls the state value shows the correct state.
light:
- platform: mqtt
schema: template
command_topic: "zwave2mqtt/nodeID_2/38/6/0/set"
state_topic: "zwave2mqtt/nodeID_2/32/1/0"
command_on_template: >
{"value": 255 }
command_off_template: '{"value": 0}'
state_template: "{{ value_json.value }}"
qos: 1
retain: false
- platform: mqtt
name: Mqtt dimmer status
state_topic: zwave2mqtt/nodeID_2/32/1/0
unique_id: zwave2mqtt_nodeID_2_dimmer
value_template: "{{ value_json.value }}"
State output from mqtt:
"value_id": "2-32-1-0",
"node_id": 2,
"class_id": 32,
"type": "byte",
"genre": "basic",
"instance": 1,
"index": 0,
"label": "Basic",
"units": "",
"help": "",
"read_only": false,
"write_only": false,
"min": 0,
"max": 255,
"is_polled": false,
"value": 99,
"lastUpdate": 1610455967351
Entities turned off:
Entities turned on:
I think I have tried every possible combination of configuration and I am really stuck.
I can set the dimmming and turn on and off again if i am pressing the switch fast, but the switch is always return to off state.
