After updating to latest version system crashed and after restoring from backup and updating again all works except mqtt light switches (tasmotized sonoffs mostly + shelly1) the weird thing is that shelly2 works perfectly.
The problem is that switch always stays in off state. If I switch to On it will light on but then goes back to off state and that result in stuck on light. if I run ‘OFF’ comand topic to related device it will turn off light. also light.turn_off works. Logs show nothing unusual
` - platform: mqtt
command_topic: shellies/shellyswitch-32C243/relay/0/command
state_topic: shellies/shellyswitch-32C243/relay/0
payload_on: “on”
payload_off: “off”
retain: false
qos: 1
- platform: mqtt
command_topic: shellies/shellyswitch-32C243/relay/1/command
state_topic: shellies/shellyswitch-32C243/relay/1
payload_on: “on”
payload_off: “off”
retain: false
qos: 1 - platform: mqtt
command_topic: shellies/shelly1-4A5895/relay/0/command
state_topic: shellies/shelly1-4A5895/relay/0/
payload_on: “on”
payload_off: “off”
retain: false
qos: 1`
